Question about Roper RAS6233KQ Top Load Washer
Taking roper washer apart.
The pump on my 97 roper washer is leaking and I need to take the washer apart but don't know how. All the repair manuals show 2 screws up on top taht when removed let you lay top down and there is everything, but mine doesn't have 2 screws so please help if you can. Thanks
  • Anonymous Aug 10, 2008
    how to take apart
  • comfyinbed May 11, 2010
    I have a roper model ras6233kq1 and don't have the screws like that. Any ideas?
  • 36 Answers
The pump is leaking. LG not much help. My husband can't get itappart to get to impeller. Does anyone know how to take it apart or have a service manual
They make them so that they are very difficult to get apart without special tools. You'll need a ''pump repair'' tech. They _do_ exist, but these days repair can cost more than ''replace.''
It _shouldn't_ be that way, but unfortunately that is the reality.
May 18, 2015 | Little Giant - OPWG-46 - External Pump -...
I'm trying to repair a leak coming from the spout. I don't know where the washer would be. Do I have to replace the whole cartridge? It doesn't seem to come apart to find the washer.
If you faucet is leaking, try this simple step to see if it will stop. First, turn the water supply line off under the sink. Next, open the valve that is leaking all the way open. Take a wrench and tighten the nut just below the faucet handle. Now turn the vale to off and open your supply line and then test the faucet again. What you are doing here is tightning the packing nut inside the faucet. Good luck.
Mar 09, 2012 | Plumbing
I have a Roper RTW4340SQ0 washer that leaks profusely when it fills and throughout the washing cycles. I've checked the water valve and all the hoses associated with it as well as the pump and all the...
This model is direct drive with a front mounted drain pump. The drain pump is THE most common leak location on these type washers! The pumps do NOT generally leak at the hoses, but from the impeller side between the pump and motor. There will be a telltale water mark on motor side of the pump shell.It can easily be fixed by popping the 2 retaining clips, removing the two drain hoses, and pulling off the old plastic pump, replacing it in the reverse order after cleaning the end of the motor shaft. Pumps run about 30 dollars. If you are sure this isn't the culprit, check for signs of leakage between the tub center and transmission, there is a tub gasket there. The tub itself, is not likey to leak, it is one piece with heat welded seams.Go to Youtube and search Whirlpool washing machine repairs, there are a number of instructional videos that show you exactly how to repair these machines and save yourself a lot of money. Incidentally Roper is built by Whirlpool, that's why I said search with that name.
Hope this sheds some light on the problem
Jan 19, 2011 | Roper RAX4233PQ Top Load Washer
Washer leaking water as soon as water starts into the tub.Washer only 3 years old
If you have a leak, the most common cause is a worn drain pump, leaking drain hoses or the hose to the air dome has come loose. You will need to remove the exterior case of the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect your washer for leaks:
If the drain pump is leaking, it is not serviceable and must be replaced, the following link explains how to replace one:
Replacement parts (if required) may be purchased on line at any of the following websites:
Prices vary between sites, so shop and compare.
Read through the instructions provided and let me know if you need further assistance. Please post back with a complete MODEL NUMBER so that I may be able to povide you with better assistance. I hope this help you.
NOTE: For future reference, if you would like to a have a complete repair manual for this model washer, has a one available for Whirlpool manufactured direct-drive washers (includes Roper) for about $20. The item number is 1170635.
Jan 27, 2010 | Washing Machines
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Roper washing model number ras7133pqo leaking
lean it back look st the pump if water on it take it off 2 clips hold it on and check seal looks bad? ...replace thumbs up
VE6GAR 73 88 99
Aug 10, 2009 | Roper RAS8445KQ Top Load Washer
Roper Washer ras6233kq1
defective pump...remove 2 screws on console corners..flip console back...disconnect lid swich harness,,,remove the 2 brass or gold color clips on each side,, now pull cabinet towards see that plastic piece with 2 black hoses replace it...onthejob
Feb 17, 2009 | Roper RAS6233KQ Top Load Washer
Roper Washing Machine Repair
I believe Roper washers are manufactured by Whirlpool. The following link should provide you with the necessary steps in removing the washer casing, so you can access the pump:
If this information is not correct, or if you require additional assistance, please let me know. I hope this helps you.
Jan 11, 2009 | Roper RAX4233PQ Top Load Washer
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Roper top load leaking from pump.....any solution other then replacing pump?
replace pump it is all spin welded together and not made for repair besides you already have it off $45-50 will finish repair normally costing 150-200 for tech to do
Aug 06, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
1,043 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
