Km1505 digital copier machine
I have two machines of above model. In one I get C 610 and in another I get C 620 error code. I have checked fixing unit (i.e. heater lamp, thermister,thermostat) found OK. While making switch on machine scanner moves and exposure turns on and afterwards error code appears. Main motor is not turning on at that time. Kindly let me know how to solve the problem.
Pratik Shah.
    Problem Solver:
  • 12 Answers
In kyocera km, c610 is Bitmap(DIMM) problem; c620 is interface problm
Posted on Jul 07, 2010
    Problem Solver:
  • 6 Answers
I would suggest that you confirm proper fixing heater supply turn on from Power source PCB to fixing unit if possible. Or replace it with a known good one (part# 2A1280551). If you are getting a low AC voltage reading at the heaters when they should be heating you may have a defective Triac or relay on the power PCB. If that is all OK you are probably looking at the main PCB as a source of the problem as it sends turn on signals to the power PCB.
Posted on Dec 31, 2007
  • dale376 Dec 31, 2007
    Sorry Part# should be 2A128051
F2 ERROR
F2 04 Content Improper cartridge (Destination error, life cycle
error)
Detail The destination of the machine differs from that
of the CRUM.
The life cycle information is other than "Not
used (FFh)."
Cause CRUM chip defect
Improper developing unit
Check
and
remedy
Replace the CRUM chip.
Replace the developing unit.
Identificat
ion error
The trade mark code of the CRUM differs.
The company code of the CRUM differs.
Model
error
The boot program model code does not
coincide with the CRUM model code.
Type error When the CRUM type is other than genuine/
conversion/production rotation.
Destinatio
n error
The machine destination differs from the
CRUM destination.
Data
abnormali
ty
When an error value is included in the initial
check information. When the max. toner supply
time is 00.
When the print hard stop is 00.
Misc error When the Misc information is other than "Not
used (FFh)
Feb 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
Error code display 00007 in ir 3300 canon copier since i have checked fuser unit thoroughly and changed the fuser flim roll of fixing unit still then the error code display manually and after switch ON...
as you probably now, the E007 is error for fixing film rotation. The rotation is checked over sensor above the film's "white" dot.
So are You sure that sensor works, is there any left overs of old film on sensor, reconnect all connectors related to the film sensor, is the "white" spot dirty or damadged, are you sure that fixing film is rotateing properly??????????
Hope that something of this will help you to find solution....
Sep 15, 2011 | Canon imageRUNNER C3200 Copier
Sir I have Canon IR 2870 a few weeks later machine shown Error 000007-000. I changed the fixing film but machine showing error again why
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Feb 22, 2011 | Canon ImageRunner 2020i Copier
The printer display an error message E007, the printer model is CANON IR 2016i
The error E007, is a common error for digital copiers, B&W segment.It means that fixing film on fixing heater is worn out.To be exact: on left side of fixing film on heater is little white square.With help of this square, photo sensor knows the condition of fixing film.If this square is "eaten", the sensor does not recognize it and automatically reports error code E007.
Your next step should be to replace fixing film. For EU region, or 230V and 50Hz current, the part number is FM2-3353 FIXING FILM ASSY.
In case of mild worn fixing film, you can try to turn off and on the copier, and get few more copies.
If the copier has over than 500 000 copies, the best solution would be to replace the whole fixing unit.
For EU region, the part number is FM2-3352.
The condition of fixing film you can check with pocket mirror and flash light.
Open the left door, above the drum unit (long green roller) is fixing unit which have warning heat lable.Place the pocket mirror under left side of fixing unit, and you should be able to see the damadged fixing film.Also if the fixing is so badly eaten, on left door should be particles of light brown color.
But however, you should replace the fixing film.
Feb 16, 2010 | Canon iR 2016i Black and White Copier
How to rectify the continious error in copier IR3300 canon
the last error generated is from the fixing unit you have to clear the error again,but if this error code (Error 003) returned a thorough check on the fixing unit is needed.Or could be the AC supply to the machine is not stable.Go to program mode got o display> analog check the fuser/fixing temp hope this will help
Jun 30, 2009 | Canon Office Equipment & Supplies
E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
Mar 10, 2009 | Canon imageRUNNER 4570 Copier
Canon np 6030
Replace the exp lamp and try again after an error clear.
Jun 25, 2008 | Office Equipment & Supplies
Kyocera Mita KM 1505 copier machine
Hello Sir,
I would like to ask you that I have a kyocera mita copier KM1505 and displays the code error like C610,So try to help me in order to resolve or fixe that problem.
Thanks
Pascal NIYONSENGA
Rwanda-KIGALI
Apr 03, 2008 | Office Equipment & Supplies
Canon iR2016
most times eoo1 can be reset in service mode if there is no damage to fixing unit. 1) Enter service mode.
Press the operation panel user mode key, 2 key, 8 key and user mode key in this order.
2) scroll to "clear" and press ok then scroll to "err" and press ok.
if that does not work you can go back into service mode as above and instead of scrolling to "err" scroll to "all" and press ok. power off then on. doing this will clear settings service techs might have made but i've done quite a few and had no probs
Mar 29, 2008 | Office Equipment & Supplies
Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Feb 15, 2008 | Sharp AR-M237 Copier
147 people viewed this question
k24674
jasbo
jasbo
