Question about Dell A920 InkJet Printer
Black Copy button works intermittently
The Black Copy button in the lower right corner of the printer does not alway respond when I press on it. In some instances I need to apply pressure to get it to respond (too much pressure in my opinion). Can I pop the cover off of the button corner to see if the contact(s) need a little cleaning??? If so, how do you suggest I do that.
Thanks,
Dave
  • Anonymous Apr 20, 2008
    both copy buttons do not work at all. Any suggestions?
Maybe use a vaccum cleaner to clean out any dirt then wipewith a ligth damp cloth. worked fr me before. try it
Posted on Mar 20, 2008
Missing part of image
Make sure that your original document is placed correctly on the scanner glass. Place the item you want to copy face down on the scanner glass in the lower right corner as shown.
12_9_2011_8_09_20_pm.jpgIf the problem continues, you may have to reset your printer to its default settings. Please follow the steps below:
  1. Power off the All-In-One (AIO).
  2. Press and hold the up arrow button and the menu button, and power the printer back on. The LCD will display Self Test Menu.
  3. Press the down arrow button until Clean NVRAM is highlighted. Press the Select button. The LCD will display Clearing. When the process is complete, the LCD will display Success.
  4. Power on the AIO.
I hope this helps.
Nov 27, 2011 | Lexmark P6250 All-In-One InkJet Photo...
Need to adjust the Settings on the Colour Mode to Black. The repair man left it on Auto now everyone in the office is not adjusting it to black.
Hello kthomas803,
You are smart to see this and respond. Even "black'pen ink has red pigment in it and although the human eye can't see it the copier can and counts that as a color copy. Hit the reset button so we know we are at the base configuration of the device.Now select black as the mode for the device as if you were about to make a copy.Now locate the "Aditional function" button to the right of the display.You will see a menu and I believe on your device the top right tab will say copy settings.Select it and scroll till tou see the "standard settings" key.Select it.The 2 options should be store and initialize.Select store and hit ok in he lower right corner.Now back out to the main screen which will require a couple of exits/resets.Now that you are back to the main copy screen select auto color.Press reset (yellow button).Your copier should now have gone back to black.Hope I have helped you,and have agood day.Please let "FIXYA" know if I helped. SPINAL
Feb 18, 2011 | Canon imageRUNNER C5800 Copier
MP110 cartridge jammed
Open the cover as if you would change the cartridge. Then press the little black button . Keep it pressed, push “copy” on the left and then the (print) black button on the right of the lcd. The printer will somehow work and work. Wait until it rests again. Then close the cover and press the black button again. Now it should copy… and print, and so on.
Aug 30, 2009 | Canon Office Equipment & Supplies
Epson r285 uses all colors to print black
To print in black ink only mode on windows, please follow these steps:
  1. Right-click the drv_taskbaricon_1.gif printer icon in the lower right corner of your screen (taskbar).
  2. Select Printer Settings. A preferences window will appear.
  3. Click the Advanced button in the lower right corner of the preferences window (if you see a Basic button in the lower right corner of the window, skip this step).
  4. Click the Black Ink Only check box.
  5. Click OK in the preferences window.
If you’re using a Macintosh, you can’t set up the printer to print in black by default.
However, your printer will still use minimal amounts of color cartridges to prime the system when your printer is in the initialization stage when turned on. Your printer also mixes all the color cartridges to make up another black, that is to prolong the life of the black cartridges.
Apr 29, 2009 | Epson Office Equipment & Supplies
My printer keeps saying cartidge jamed
Open the cover as if you would change the cartridge. Then press the little black button . Keep it pressed, push “copy” on the left and then the (print) black button on the right of the lcd. The printer will somehow work and work. Wait until it rests again. Then close the cover and press the black button again. Now it should copy… and print, and so on. Hope it helped. Let me know.
Nov 22, 2008 | Office Equipment & Supplies
Scan Reads
Press the user tools/counter button. Select the counter in the lower right corner on the lcd display. If you need a hard copy. Press print on the screen. Press the green button on the copier.
Sep 05, 2008 | Ricoh Aficio 450 Copier
Xerox B/W Copier XC 1044
Here you go. If you have no underlying problems this should work. If it comes right back, you have a fuser problem.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jun 09, 2008 | Office Equipment & Supplies
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    MEMO:
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Dell A920 InkJet Printer Logo
26 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
