Blueant Blue Ant 091193 Supertooth II Hands-Free Bluetooth Speaker Wireless Headset Logo
Posted on Oct 20, 2009
Hi, i have a supertooth light BTslbc3 and it has
Hi, i have a supertooth light BTslbc3 hands free kit and it has worked well wth my nokia 6500 classic. i have just upgraded to the nokia 6600i slide and it wont pair, can you help please as i'm lost without this device? The bluetooth connection appears to be working in both my phone and supertooth, Thanks Julie
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Oct 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
1749
Points
17
Did you DROP the BTslbc3 from your old phone? If not, it may not pair with the new one. That is just a suggestion you may want to try. It may not pair with the new if it is still paried to the old. Hope this helps.
2helpful
I need a visor clip for a BTONE Supertooth hands free kit as mine has broken. Where can I get one from?
Hi, this is SuperTooth, sorry for the incovenience. Please contact us: contact at supertooth dot net
May 06, 2011 • Cell Phones
I have the blueant bluetooth model btslbc3 and the y touch 3 g tmobile cell I can not synk them... Help
Do you have the Supertooth 3, Supertooth Light, S1 or S2?
It would say on the back of the unit, look for supertooth.
Or go to www.myblueant.com and search for the product specifically.
Rylan
Will not pair up with supertooth buddy hands free kit, do you know why?
you cannot pair this cell to supertooth, because the nokia 1600 does not have bluetooth capability
nick
9helpful
2answers
I have a BlueAnt Supertooth BTSLBC3 car speaker that won't pair up to my new BlackBerry curve 8530 phone. The BlackBerry won't see the BlueAnt Supertooth BTSLBC3. The BlueAnt Supertooth BTSLBC3 is paired...
Pairing Your BlueAntStep 2: Activate Pairing Mode on the Supertooth Light
  1. If the microphone arm is open, close it to turn the Supertooth Light off.
  2. Press and hold the answer button.
  3. With the answer button held down, open the microphone arm.
  4. The lights will start flashing red and blue, indicating that the Supertooth Light is in pairing mode.
You now need to activate Bluetooth
2helpful
Bluetooth BTSLBC3 antenna
Unscrew the back, inside the back cover there is a tiny black latch, about 1/2" wide. it comes unglued from the plastic guide it is in, that is why your antenna will not lock. You can carefully glue it back in with some superglue, or a piece of tape will hold it in very well too. Worked fine for me.
19helpful
2answers
Lost manual for BTSLBC3
Go to http://www.fixya.com/support/t1267258-pairing_problem_supertooth_btslbc3 All solved! :)
235helpful
5answers
Pairing problem for Supertooth btslbc3
-----How to Create a new Connection----
Pairing with Phone
1. Turn off all devices (ST Light and Phone)
2. Turn on Phone
3. Goto Bluetooth menu on the phone (might be in connectivity)
4. Go to device list or paired devices (make sure bluetooth is turned on)
5. Delete any old profiles that are still in there.
6. Goto the Supertooth Light (BlueAnt)
7. Hold down the green button (send button)
8. while holding it down, open the microphone
9. the light should start to flash "red" and "blue" (you can release the green button)
10. go back to your phone, and go into either 'device list' menu or 'paired devices' menu on your phone.
11. click on either search, add or new devices. Function depends on different phones
12. when the phone has found the device, it should say 'ST Light BA V1'
13. select it, then enter passkey "0000"
14. If your phone ask for authorization or auto connect, just click "yes"
65helpful
3answers
Supertooth btslbc3
Hope this helps..............
Pairing with Phone
2. Turn on Phone
By now, you should be connected to your device. Always remember to close the microphone before you leave the car.
Otherwise, it will slowly drain the battery. If you want to reconnect, just simply open the microphone.
Make sure you turn off your phone once every 2 weeks to reset the phone memory. This will help give a better
performance and clearer sound.
Top Blueant Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
