Question about Toshiba Satellite A25-S207 Notebook
COOLING FAN AND COMPUTER CUTTING OFF
I have the A25-S3072 series. Is the CPU Fan (fan I can see from underneath the laptop) suppose to continuously run? It only runs intermitently and when I run my laptop from the portable battery it will cut off after about a 1/2 hour as if someone pulled the plug. However, it will not cut off when funning from a/c power. After trying to troubleshoot I took it to the Geek Squad yesterday and they told me that it was cutting off because the computer was getting too hot off the battery power because the fan was not continuously running and that I needed to replace the CPU fan.
Does this make sense?
Sincerely and Thank you,
Dave Long
  • DaveLong Dec 29, 2007
    Gentlemen, thankyou for your recommended solutions. I've taken it apart, and cleaned the fan and CPU heatsink. I turned the laptop back on (portable battery power at 100%) and so far it seems to be running fine. It is down to about 26% and has not cut off unexpectedly. I will do this a few more times to test. Also, the fan continues to run only part time, so I assume that it isn't suppose to run all the time, only when needed to cool the computer. Also, I will download and run cpu-z and speedfan. I will let you know how it goes. Thanks for your help.
    Dave Long
    Genius:
  • 1,601 Answers
Dave, If you mean that the laptop cuts out because it gets too hot.
Yes, I do agree with them. The fan on a laptop is a VERY important part of a laptop. Because of it the small size the temperature inside gets very high. The fan will run when the temperature reaches a certain degree. If you get it replaced or do it yourself, remove the dust that accumulates inside.
Posted on Dec 29, 2007
    Sergeant:
    Champion:
  • 243 Answers
When you say cut off are you meaning that the laptop is shutting down?
The fan is only running intermitently when on battery as the laptop is running in power saving mode
and the speed drops when not needed as well as the cpu voltage
therefore reducing the heat produced and the nedd for the fan to run.
Try using a program called cpu-z and it will show the speed of the cpu going up and down as needed. Also use speedfan to sjow you the cpu tempreture.
Hope this helps and puts your mind to rest ? :)
What kind of cpu cooling fan can I use in a Acer America ASE380-UD420A desktop computer?
Cooling fan to CPU are come along with the CPU. You can use any other fan, having speed regulator pin, ie, the connector wire to it will have three conductors. Keep a close look at the size and seating screws to its body to the heat-sink of the CPU.
Jul 22, 2014 | Averatec Sotec 3200 Series Fan with...
My computer is not cooling (acer aspire 6530). After a point the power gets off (i think it's a security safety). Where can i order a new fan?
I doubt that you need a new fan, they are quite long lived, UNLESS you cannot hear the fan cutting in?
My guess would be that the heatsink and the cooling copper matrix have become clogged and will need the fan assembly removing and cleaned. To do this, the laptop may need taking apart, unless there is the large inspection plate underneath the laptop, in which case, the assembly is easy to get at.
If you do disturb the heatsink, make sure you apply fresh CPU grease on the chip before re-assembly
Jun 19, 2011 | Acer Aspire 6530-5143 Notebook PC
HP DV2910us -where to order cpu cooling fan for
Best place to look is ebay. Look it up as a DV2000, as far as I know all the dv2000 series use the same cpu cooling fan. Otherwise, if you have the laptop apart, use the serial number or m/n on the part to look it up on ebay. I do this daily at my computer repair store and have lots of luck with hp laptop fans.
Apr 30, 2010 | HP Pavilion DV2910US Laptop
The location of the cpu cooling fan
Look underneath your Laptop, you should see some ventilators in the casing, you CPU fan will be near there. If you've got you laptop running, just feel around any of the vents, the heatsink, ducting and fan will be locate close to where you can feel warm air flow.
Apr 10, 2010 | Sony CPU FAN CPU Fan
What happens if one powers on a laptop compaq evo n110 series
it's likely the fan has failed. it should immediately shut down and even if it doesn't... if the fan is not spinning you need to put a new fan in first. it is easier to replace a fan then a cpu and heat will basically kill it.
Dec 03, 2009 | Compaq Evo N110 Notebook
A problem with the cooling system is detected. Satellite A25-S207
The sensor that reports the cpu temperature could be faulty or could be fan loose from cpu or faulty motherboard .
Aug 02, 2009 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite A25-S207 Cooling system not working
Yes Its possible to fix. However your conclusion about fan might not be totally correct. as there might be different reason as Fan works CPU controlled. It should be diagnosed by hands on technician. If part requires the replace it should be done by someone who is skilled. You may take to Toshiba Authorized Centre or Independent Computer Technician. You can go to http://pcrepair.toshiba.com and locate the nearest service center.
Good Luck
Dec 29, 2007 | Toshiba Satellite A25-S207 Notebook
Cooling system
Computer hardware related downloads Operating System:, Windows 95, Windows 98. Description:, CPUCooL is a multifunctional utility: 1) Cooling the CPU under Windows 95 / 98.
Read instructions, Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Toshiba Satellite A25-S3072 Notebook
Toshiba Satellite A25-S207 Notebook Logo
365 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
