Question about ASUS MyPal A626
ASUS A626 Wireless 802.11b/g
It seems almost impossible to get a wireless signal unless you within a few feet of the router. I have already set the card to on the PDA to be at 100% power but that doesn't seem to help at all. Also, ASUS tech support is of no help.
Any thoughts on what I might be able to do to improve the wireless connection?
  • 2 more comments
  • kolohe4u Dec 30, 2007
    I am having the same problem. It looks like it is connecting at full meters and then drops to less than half even if I am holding it right next to the router. tried changing the settings and hard resetting and nothing works. Any ideas? maybe a return is in order??
  • LouieO Jan 08, 2008
    Same exact issue here!
  • ahtripp Jan 17, 2008
    I have the same problem: Wifi signal strength is good at 3 feet from
    router, fair at 10 feet, and poor beyond that. Other Wifi devices I
    have are at least good everywhere in my home. Similar problem at
    remote Wifi sites at airports, coffee shops etc.
    I have gone through all the troubleshooting steps with no change noted.
  • juliepete Apr 06, 2008
    I have the same problem. I have to get within 5 feet of the router to get better than a fair signal. I have an ipaq with wifi and it shows very good to excellent signal when the asus a626 has poor or no connectivity.
  • 86 Answers
It doesnt go thru walls very well, 5m seems the limit with deteriorating signal. Rather get your wireless router out into the open (not hiddden behind a computer desk) and the antenna pointing in the direction of the other one. There is a signal strenght utility that asus has that stays resident as an app. use that to assertain your signal viability
Posted on Aug 16, 2008
I SET UP RAUTER AND WORKS JUST FINE CLOSE TO THE MODEM BUT AS SOON AS I CONNECT THIS 120 FEET, IT DOES NOT WORK AT ALL. THANKS
This has happened to me many times. There are a few ways to get around this.
120 Feet is well within the range of the device. However that range is affected by a wide range of factors.
  • Walls - The signal will have a hard time penetrating some types of construction (e.g. Concrete, Lathe and Plaster)
  • Obstructions - Other things can also block the signal. Freezers, speakers, electronics, extensive wiring.
  • Environment - Some areas are more or less wireless dead zones. Nearby airports, radio antenna or other broadcasting equipment can interfere with the wireless signal.
If your 120 feet include 8 lathe and plaster walls, with a ham radio and a walk in freezer; you want to just get a nice long cable instead of proceeding with my further advice. However if there are only a couple of drywall walls and no blockages proceed.
  1. Try adjusting the location of the router. Often just moving the router to a high shelf or over a few feet can solve this type of issue.
  2. Can you connect at any range between close and 120 feet? Some testing could help identify the source of your signal loss.
  3. Try to build an antenna?
  4. Get a cable
At home I use a cable even though I'm mere feet away from my wireless router. I play online games and the wireless signal regularly experiences fluctuations in connectivity. This represents just how delicate the wireless connection really is. Imagine the invisible waves trying to penetrate your 120 feet and look for anything that might obstruct.
Mar 07, 2011 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
Loosing internet connection every 15 minutes
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | Linksys WRT120N Router
Have a motorola surfboard wireless router. Needing to figure out how to change the channel it is using so we can get a better signal.
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
  2. Wireless settings of the router are still set to default.
  • Placement of the router: MFG suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
Having default wireless settings on the router may cause conflict with other routers within your network range. MFG suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
Nov 11, 2010 | Arris SURFboard SBG900 Wireless Router...
It seems that the signal is strong next to the router, but drops to 1 bar within 30 feet away? What is the most likely solution.
Routers generally have a strong signal for up to 10 meters. However no obstacles should be in the way. 30 feets is about 10 meters so the router is loosing its signal strength. If you would like to extend the strength of your router you can buy a range expander. This device acts as a repeater of the signal so from 10 meters you can go to 15 or 20 meters.
Mar 08, 2010 | Hawking Hi-Gain 802.11g MIMO Wireless...
I am trying to connect my asus mypal to my wireless internet
Hi, I helped a friend of mine with his wifi setup. His WEP Key was on the side of his router. I don't remember the exact work but it was something Key. It was 10 numbers long just right for a 64 bit key. If you are using Win XP there is a wifi setup in there. I have a mypal A626 and had it up and running in a few minutes on my wifi system. If you have security, you will need to find the code in order to get a connection. grader01
Apr 12, 2009 | ASUS MyPal A626
I have a Dynamode 6004 W-G1 wireless router
To improve wireless signal from your wireless router you can try changing the wireless channel of it from the router setup page, set the wireless channel to the highest one so it will avoid interferences on your location........
Jan 15, 2009 | Dynamode (HT809STP) Networking Hub
My wireless internet connection is getting interrupted every few minutes
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
  • Manufacturers suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
Having default wireless settings on the router may cause conflict with other Linksys routers within your network range. Manufacturers suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | Computers & Internet
Asus A626 WiFi
I fixed my problem with my D-Link DIR-625 router by going and changing a couple of things. I'm not sure which one did it, but this is what I changed:
1. Under the advanced tab turn off 'Wi-Fi Protected Setup'
2. Under the advanced tab - Advanced Wireless option:
Advanced Wireless Settings Transmit Power : High Medium Low
Beacon Period : (20..1000)
RTS Threshold : (0..2347)
Fragmentation Threshold : (256..2346)
DTIM Interval : (1..255)
802.11d Enable :
WLAN Partition :
WMM Enable :
Aggregation Limit : 8 Kbytes 16 Kbytes 32 Kbytes 64 Kbytes
TPC Max Gain : (0..50)
Aggregation Max Size : (2000..65535)
Aggregation Num Packets : (1..64)
Force Short Slot for 11N Clients :
Short GI :
Dec 11, 2008 | ASUS MyPal A626
I can't stay connect on-line
  • 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Thanks, Joe
Nov 25, 2008 | Linksys Wireless-G WRT54GS Router...
ASUS MyPal A626 Logo
400 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
