Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582
Problem for Generac Guardian Ultra Source 15,000 Watt Portable...
Generac NP 50G Stops after 2-30min.
By gkirkpatrick on Oct 20, 2009
I just bought a RV with a Generac NP50G with about 500hrs. It will run for 2min to 30min fine then shut down, work fine with load. Checked the overheat sensor and it is disconnected so not the issue. Though it might be fuel filter but it stops quickly like it loses spark (not sure that is true though and it is not seized from over heat). If I try to start it quickly when I hit the start button nothing happens but in about 30 seconds it will start right back up.
Any help would be greatly appreciated
Comments:
Oct 26, 2009
- I replaced the fule filter, oil pressure sensor, and choke solinoid. And the issue is still exactly the same. Strats well then shuts down after a couple minuests or less. I am confident it is loss of spark, there is no "sputtering" it just shuts off. I also noticed that the previous owner tried to bypass the oil sensor as there is two wires to it, one chasis ground and one that goes back in the engine (I assume control board). Also the over heat sensor is disconected. I also noticed that the choke solinoid is always charged (choke open). It was hot out when first starting but still assume the choke would shut when first starting, is this normal?
Oct 28, 2009
- The problem ended up being a dirty fuel bowl in the carb. After cleaning it ran fine. I now have a seperate issue I will post though.
Best Solution
posted on Oct 20, 2009
Very Helpful)
SRF518
Rank: Guru  Tools - Building & Power  Expert
Rating: 87%, 68 votes
check the oil sensor circuit. I know when I take out or short out the sensor ckt on mine, it'll keep on running. low oil isn't good for any motor.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Parts are on order and will verify the fix. But this makes a lot of since based. " - gkirkpatrick
Popular Solutions for Generac Guardian Ultra Source
Questions and Unsolved Problems for Generac Guardian Ultra Source
Do you recommend Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582?
Answer
Answer
need otc 5 gas monitor rg 240 operating manual
Answer
how do you get into the parameters to change resolution
Answer
I need parts for an Berger Model AK-46 Transit. Specifically the Trianglular mirror that is mounted... (More)
Answer
have an old sears brand thermostat that I am replacing...two wires on back not marked one held in w/... (More)
Answer
item # 0045821 serial # 4315753t it is a generac portable gen it runs great it. the engine is not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Generac Guardian Ultra Source...:
Top Measurement Tool Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Measurement Tool Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
