Question about Bose LifeStyle 50 System
Personal Music Center Won't Turn On
New batteries but can't get the OFF signal to turn ON.  The interface is working and all connections are correct but it won't power up properly.  Whatever button I touch on the interface it just beeps.  It was working properly until I disconnected and took it to a party (worked fine) and then came home to reconnect it and experienced this problem.  Help!!
4 Suggested Answers
  • 4 Answers
SOURCE: Bose Av38 Media center remote contro issue.
problems of conectivi betwen samsun and bose products many people whit same problem,
Posted on Apr 22, 2009
SOURCE: The music center does not communicate with the
i have the same problem did you find out why
Posted on Apr 01, 2010
SOURCE: No display or power to
check the power supply section burned components
Posted on Aug 01, 2011
Remote shows no response
I have just had a major problem trying to get the handheld (touch screen) music centre to communicate with the multi room interface. It took over a week to sort out by trial and error, but here is the solution :
1. Disconnect everything from the multi room interface apart from Room A and the CD player (blue connector).
2. Turn off the electricity supply at the wall (turning off any in line extension lead is not good enough - it needs to be at the wall socket). Leave turned off for at least 2/3 hours.
3. Turn back on and then leave it again for 2/3 hours.
4. Touch the music centre and you should find that it has now registered with the interface unit.
5. Connect the other rooms and input sources with the power switched on (contrary to instruction manual which advises you connect everything before powering up).
6. Test each input systematically as you connect them.
Hope this helps. I was on the verge of buying another multi room interface (I have 2 music centres and neither worked so assumed in was the interface at fault), at a cost of £200, so now glad I persevered with resetting the system !
Mar 03, 2014 | Bose LifeStyle 50 System
Lifestyle 50 not responding
Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
Jul 28, 2013 | Bose Lifestyle 40/50 Music Center Used...
Why dose the speaker/stereo echo the turn signal? Why dose it play random music when it's on AUX mode? How can I fix the USB problem?
First disconnect the battery then wait ten secondsand reconnect this should reset your radio and other electronocs in the car
Apr 03, 2013 | Audio Players & Recorders
Left turn signals won't flash, Right side works fine. Replaced front and rear turn bulbs (rear was burned out). Bulbs come on fine on the left side, they just won't flash.
Gday mate, we had a problem with another late model vehicle similar to that, the bulb that was put into the reverse light was not exact brand product ( ohmage was slightly wrong ) and fowled up computer, correct bulb in place and disconnect battery to reset K A M ( keep alive memory) problem solved, BEWARE, some vehicles cannot have KAM reset except for dealer computer tethered reboot , just try putting the factory correct bulb(s) in and see how it goes, geoff. hope this helped.
Feb 11, 2012 | 1998 Buick LeSabre
Hello I have a bose surround sound system in my house, both inside and out. It appears that only the inside portion of the surround system works and the remote for the outside portion the RC48S2-27 model...
I think we're discussing the Personal Music Center II.
I had to back into the product from the remote model number. Can we assume you also have one of the compatible LS systems (18 or 28 Series II or the 38 or 48) ?
You can go to Bose.com and search for it or register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Bose-Personal-Music-Center-II-Universal-Remotes-manual/id/526dj583/t/2/
The first item in Troubleshooting (page 28) might explain what's happening.
Jun 18, 2011 | Bose PERSONAL music center II System
My battery fell out of my phone I tried turning it on but it seems the end button doesnt work. I tried plugging it in but it goes to the charging screen but won't turn all the way on please help!
Hi,here are the basic steps to check your phone problem.
* Try another battery to check if that's the only problem,
* also try another battery if there's a response in charging.
* check the battery terminal if there's a corrosion as well as the battery interface, re-align battery terminal pins if its leveled.
* if nothing the above works,consult a mobile service center for assistance.
thank you for visiting fixya.
Jun 16, 2011 | LG Cell Phones
My camedia Olympus c3000 won't turn on with brand new charged batteries.
TROUBLESHOOTING
OPERATING PROBLEMS
The camera does not work.
1 The power is OFF.
[ Set the Mode dial to turn on the power. (P. 36)
2 The batteries are loaded incorrectly.
[ Reload the batteries correctly. (P. 28)
3 The batteries are exhausted.
[Replace the batteries with new ones. (P. 28)
4 The batteries are temporarily unable to function.
[Keep the batteries warm while using the camera.
5 Power has shut off to conserve battery consumption.
[Operate the shutter button or the zoom lever.
6 It is connected to a personal computer.
[The camera will not operate while it is connected to a personal
computer.
Jul 14, 2010 | Cameras
The Graphic Equalizer pattern control is not working correctly - I can hardly hear the vocal on my CD's when playing even though I've selected vocal. Vocals are outplayed by background music.
That sounds more like a polarity, or phase problem. Make sure your speakers are hooked up correctly, with the correct colors going to (+) positive, and (-) negative. Make sure your rca connection are correct, and that every connection has a left and a right. No stereo-to-mono adapters.
Is setting to "vocal" an eq selection, or a "dolby" stereo selection?
Are you using a dolby surround stereo receiver with left, right, center, rear, etc.?? If so, try turning off any effects, or anything that would send signal to the center speaker.
Lastly, depending on what the source of your music is, it is possible if your connections or receiver settings are not correct...that the music upon playback will be out of polarity, meaning the vocal portion will cancel out. Combining left and right signal together can sometimes do this as well.
Apr 09, 2010 | Denon D-C30 Shelf System
How do you get the sirius radio hook up to be displayed on the interface
If you have all the devices hooked up correctly using the JVC/Sirius interface. It does not recognize it if it's defective. Most common problem sirius/xm has. The miniport for the antenna connection has a bad solder joint and thus is inop. if it does turn on by chance, it will say "acquiring signal" and that's it. If it's new get it replaced. If it was working prior to this, and it's out of warranty, go on Ebay and get a rebuilt tuner, their about 50.00 and more reliable than new. Hope this helps
Jun 26, 2009 | JVC Sirius KD-LH300 CD Player
Mp3 won't turn on
These don't charge. They use a battery.
Jul 01, 2007 | Coby MPC-848 MP3 Player
Bose LifeStyle 50 System Logo
49 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
