Question about Dryers
How to Change light bulb (yes, really...)
I am your great grandmothers age. Need to change light bulb in Hampton Bay ceiling fan Model 04890. HELP please! How????
  • 5 more comments
  • Anonymous Mar 02, 2008
    I just broke my glass globe to bits trying to get it off. It is supposed to twist off but after an hour of screwing with it, it broke into several large shards of falling glass. Be careful!
  • Anonymous Mar 08, 2008
    The globe is smooth all the way around; no screw or nut at bottom. No set screws. Housing and light are all one unit and the light bulbs are totally sealed. Tried unscrewing whole unit, tried lifting the glass to rotate it up and out, tried pushing and pulling every imaginable part.
  • soose Jun 03, 2008
    I just received a replacement globe for my Sidewinder and cannot figure out how to attach it. The ceiling fan/light is fully installed except for the cover (globe). There must be a trick to it...but, I haven't a clue what it is. Can someone help?
  • Anonymous Jan 15, 2009
    I have a hampton fan and i need to change the bulbs but i cant take the center out. it has a flat glass bowl and on the side are a solid rail on the side. How ever its shows to turn to open and i have but it wont budge
  • Anonymous Feb 23, 2009
    I can not take the cover off from the hampton bay fan. Can you help me!!!
  • Anonymous Apr 14, 2009
    where do you buy the replacement fixtures for the bulbs with no set screws on a hampton bay ceiling fan with remote
  • kwframpton
    kwframpton Mar 28, 2013
    I also broke glass. Where do I find replacement?
    Scholar:
  • 44 Answers
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Posted on Feb 09, 2008
Finally, we got it. As some of these solutions suggest, the trick is to hold the metal rim while turning the glass globe to the left. It took two of us, one holding the rim and the other turning, but voila, there it is.
Posted on Mar 23, 2008
I just helped a friend with this problem last night. There is no center nut to unscrew on these whole glass globe models. You have to push up slightly on the glass with a small bit pressure while you hold the metal housing directly above that the glass is attached.
Then you turn the glass globe approximately 120 degrees counter clockwise as you are looking up at the fan from below it. There are three metal impressions located at 120 degree increments that the globe uses to hold it in place and lock-in. Too much pressure and that thin glass will shatter. We put some white grease on the globe rim before reinstalling it to help it not be so hard to twist off next time.
Posted on Mar 05, 2008
Posted on Mar 02, 2008
I have this fan and just changed the light bulb. There are no screws or nuts to unscrew. You turn the light fixture itself, counter clockwise. I found that mine stuck a bit and recommend holding the nickel folds holding the glass fixture and not the glass itself. The whole bottom piece should turn and come off.
Posted on Feb 18, 2008
Change upper light bulbs on hampton bay model 560-084
Please check the manual. If you dont have a manual you can download a free copy from here
Hampton Bay Lighting Manuals
These manuals are courtesy of Hampton Bay
Dec 02, 2016 | Hampton Bay 24002 Ceiling Fan
I need a replacement LED light bulb or kit for my Hampton Bay fan model number AM215-BN. Where can I get one?
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Light-Kits/Hampton-Bay/N-5yc1vZc5t3Zp4
Aug 14, 2016 | Hampton Bay Dryers
How do I change the light bulb in a model 66266
It twists off counterclock wise. If that doesn't work, try spraying some WD-40 around the glass. Wipe off excess oil.
Jan 16, 2014 | Hampton Bay Dryers
Hampton Bay Sidewinder ceiling fan. For ten years, wall mounted control functioned until it 'blew' when electrician was working on a remodel of another room. Installed another control (Progressive...
You called customer care about a Hampton Bay & they sent you Minka Aire??? Hampton Bay is a store brand for Home Depot. If The fan came with a remote, you probably need the one for your fan.
Aug 24, 2013 | Hampton Bay Sidewinder 04890 Ceiling Fan
My hampton bay ceiling fan it a rounded light and I don't know how to get to the light bulb to change it?
ther are three small screws that need to be loosen, once these are loose, the globe will come off and you can now change the light bulbs
Oct 18, 2009 | Madison Avenue 04889 Hampton Bay Ceiling...
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
Light kit has light bulb size that I cannot find bulbs for
Melanie, you must have gotten a bad batch of bulbs. I have installed over 100 Hampton Bay ceiling fans and I have dropped them from up the ladder and have them bounce across the floor with no damage. I think they must have allowed a substandard batch to go out.
Home Depot is where I buy my replacement bulbs. Hampton Bay make fans exclusively for HD.
You can easily change lighting bases, as the wiring is the same for all Hampton Bay. You may even appeal to Hampton Bay on the internet and they might send you the kits. But I don't think you'd have success in a store.
If you try replacing them with bulbs from another Home Depot you may find them much hardier. I wish you the best of luck, and if you need additional help please write back.
Sirwriter
May 25, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Bulbs burning out in Hampton Bay ceiling fan
I would suggest getting an electrician to check the current running through the wiring. I had installed a similar fan in my grandmother's house a couple of years ago and had the same problem. After a couple of months of constantly changing bulbs, I brought in an electrician to check the current and found that there was a short in the wire which kept causing just enough of a current surge to blow the bulbs.
Nov 29, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
No middle speed.
Replacing the pull switch (reostat) should have solved your problem. Try going to the internet at www.google.com and in the Google search box enter "Hampton Bay Fans homepage". If any of these suggestions have been helpfull, please rate my solution. Thanks D. Lange
Jul 31, 2008 | Hampton Bay Sidewinder 04890 Ceiling Fan
Dryers Logo
2,605 people viewed this question
Top Dryers Experts
Marvin
Marvin
