Kenmore Elite 45986 Front Load Washer
Problem for Kenmore Elite 45986 Front Load Washer
The rubber gasket that keeps the seal when the
By pmeldrum on Oct 20, 2009
The rubber gasket that keeps the seal when the door is closed has a tear in it, is it easy to replace??
Solution #1
posted on Oct 20, 2009
Not Rated)
jsrock516
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 96%, 7220 votes
Replacing the rubber gasket (bellow) is not a difficult process. If you are attempting to replace the door bellow on a Whirlpool front loader, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip!
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 45986 Front Load
Questions and Unsolved Problems for Kenmore Elite 45986 Front Load
Do you recommend Kenmore Elite 45986 Front Load Washer?
Answer
Answer
the hard plastic around the front of the barrel has broken off and the washer jumps during spin
Answer
F71 code flashing mid cycle on the washer; can't restart.
Answer
i have a kenmore elite calpso washer it stops on the timer and wont finish the cycle whats wrong
Answer
what is the wattage on model110-450874-400
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
