Question about Bose LifeStyle 50 System
Music center control can't find room A on multi-room interface unit
I have replaced the batteries, assured all connections were correct, went to troubleshooting guide and followed instructions to reestablish link with the interface but still the A,B,C,D LED lights revolve continuously and can't find the proper room.
The unit is receiving power, but any button I try to press under SOURCE just beeps back without doing anything.  I can't get the unit to come out of the OFF position either.  Maybe that is the bigger problem but it has new batteries in it.
2 Suggested Answers
SOURCE: The music center does not communicate with the
i have the same problem did you find out why
Posted on Apr 01, 2010
Need to know why the grasslin Fm/1 Digi 20-L timer won't let me program it. I push reprogram button And it went back to just blinking the days of the week on top but won't respond to anything I push
Likely solution: Current time of day was set without holding down the timer (or clock symbol) key.
Other possibilities: Maybe the back-up battery is depleted and you need to connect timer terminals to correct power source ... these models vary 24V, 120V, 208-240V... look for markings on timer
More possibilities: Troubleshoot following link: This is older version timer.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#module
Manuals on following link:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TRAX
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 11, 2015 | Hardware & Accessories
Bose system (Lifestyle 50)
Did you try leaving it unplugged for a few hours?
Feb 24, 2008 | Bose LifeStyle 50 System
How to replace a battery to First alert mod sa303
http://www.firstalertstore.com/store/images/pdf/sa305cn3-10-year-battery-smoke-alarm.pdf
Follow the link above to download the user guide. There is a door that opens to the side of the device that contains the battery. The drawing is not very good. I believe the door is like a tray that holds the battery? Take care that the polarity is correct...often times 9V connectors will permit improper polarity connections which could harm the unit and destroy the battery. Fortunately, it's not usually too difficult, especially if you pull the unit down first so you can see better...good luck!
Feb 13, 2015 | Home
My prestige elite10 is not working I was charging it when I picked it up the screen went white so I then pushed the reset button but then it turned off and never came back on after that
I had one just like it. ,i ran with the same issue wat i did i reset it then i put it bak to charge for like an hour or two then it started right up again
Jan 25, 2015 | Audio Players & Recorders
Bose lifestyle one room doesn't connect and the remote says it won't connect to media center
Look in the instruction manual and make sure that you have set the codes correctly, the house code for the remote, as well as the room code for the second room. Also check the batteries in the remote control, especially when the room as far away from the main room, the batteries need to be full in order to reach the center. I assume we talk about a wired system? When this is a wireless connection to the second room, it may need a reset, unplug and re-plug the wireless adapter, there should be a pilot light in the back of the wireless adapter, which should be green. If that does not help, call Bose.
Jun 07, 2014 | Bose Lifestyle 48 System
Remote shows no response
I have just had a major problem trying to get the handheld (touch screen) music centre to communicate with the multi room interface. It took over a week to sort out by trial and error, but here is the solution :
1. Disconnect everything from the multi room interface apart from Room A and the CD player (blue connector).
2. Turn off the electricity supply at the wall (turning off any in line extension lead is not good enough - it needs to be at the wall socket). Leave turned off for at least 2/3 hours.
3. Turn back on and then leave it again for 2/3 hours.
4. Touch the music centre and you should find that it has now registered with the interface unit.
5. Connect the other rooms and input sources with the power switched on (contrary to instruction manual which advises you connect everything before powering up).
6. Test each input systematically as you connect them.
Hope this helps. I was on the verge of buying another multi room interface (I have 2 music centres and neither worked so assumed in was the interface at fault), at a cost of £200, so now glad I persevered with resetting the system !
Mar 03, 2014 | Bose LifeStyle 50 System
Equity model 29002-1
Anon, replace battery with a good strong AA Energizer or Duracell Alkaline not a cheap battery, make sure battery contact point in clock are clean and no corrosion. If this does correct the problem, the clock mechanism is probably just wearing out from age which is normal unless it is digital. Read through the links and learn how some time mechanisms can be made to work properly again. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Maintain Battery Powered Quartz Wall Clock
Save Money Quartz Battery Wall Clock Repair Fixing Disney Winnie The Pooh...
Clock repair and troubleshooting
How to identify and replace quartz clock movement
Feb 15, 2014 | Equity By La Crosse Equity 29003 10"...
Acer troubleshooting guide
Hi Sir,
You have a problem with your BIOS, to settle it down follow the followings:
1. Open your Computer Case
2. Pull-out the CMOS battery,
3. Replace the CMOS battery with a new one.
4. Set the BIOS again into default, with correct time and date.
ENJOY....
Hope it will help you.
Nov 05, 2013 | Computers & Internet
Lifestyle 50 not responding
Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
Jul 28, 2013 | Bose Lifestyle 40/50 Music Center Used...
Had F70 &F71 changed ccu and ui won't power up just beeps
Even after they replacing the CCU and the MCU, I still kept getting the three beeps and the F70 Error... the fix was replacing the front controller boards (where the knobs and buttons are). check your connections also, and that they are in the proper slot.
Oct 31, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
Bose LifeStyle 50 System Logo
55 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
