Question about Kitchen Ranges
I CANNOT TURN OFF THE "LOC" MESSAGE
I TURNED THE OVEN ON SELF-CLEANING MODE. AFTER IF WAS DONE THE "LOC" APPEARED ON THE SCREEN AND IT'S BEEN LIKE THAT FOR OVER AN HOUR NOW. HOW DO I TURN IT OFF? I LOST MY INSTRUCTION MANUAL.
YOUR REPLY WOULD BE MUCH APPRECIATED. THANK YOU.
  • badcook Jan 26, 2008
    I forgot something in the oven and it got too hot I guess and the code Loc came up and has been there for weeks - I haven't been able to use the oven at all in the mean time.
  • Anonymous Oct 25, 2008
    I cannot turn off the loc message
How do you reset the breaker?
Posted on May 10, 2008
  • 640 Answers
Try resetting the circuit breaker to the oven,let me know.
Posted on Dec 31, 2007
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: i CANNOT TURN OFF THE "LOC" MESSAGE
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (a couple of hours). Of course doing a hard reset erases all glitches as well as user settings and configurations, the unit will revert back to factory default 9assuming no hardware fault).
Maytag Error Codes:
LOC - this means configuration setting changes will not be allowed F9-1 Latch lock upper F9-2 Latch unlock upper F9-3 Latch lock lower F9-5 Latch unlock lower F9-6 Latch both lower
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 27, 2008
How do I turn the temp down after oven has been on for a while. 'Loc on' message is showing and will not allow me to turn oven on.
Can you provide some additional details to help me help you? What kind of stove (make/model) and does it have any kind of self clean mode?
Without knowing the above details generally speaking of the oven is already preheated, to change the temperature you would hit the bake/preheat button to then adjust temp up or down with a digital stove. The dial stove from is self explainatory!
That loc on message may be because you have a stove lock lever or feature that prevents the stove from being opened when enabled, or when the stove is self cleaning. This may prohibit the adjust meant of temperature when the lock is on, or the stove is running through the self clean..
Again all just a general thought without knowing the above information... if you can post back or let me know is this was helpful in anyway to you! Thanks!!
Feb 13, 2017 | Ovens
Electrolux oven wont work after cleaning
Hi ja1078063,
I understand you having trouble getting your oven to work after using the self-cleaning mode. Does any part of the oven work? Confirm a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc.
Does "Loc" appear in the display if any button is pushed?
The Oven Lockout feature automatically locks the oven door, prevents most oven controls from being turned ON. Press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked.
Best Regards,
Jan 22, 2014 | Electrolux EW30EW65SS Stainless Steel...
Oven doesn't heat
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 17, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The oven is giving error code LOC
amana self cleaning convection oven displays an F9 code.
Sep 06, 2011 | Maytag Kitchen Ranges
The LOC on messsage appears on the screen when we go toturn the oven on. NEED the OVEN. What could we do to fi it?
The control lock has been activated. This feature is useful when you are cleaning the panel so that you don't accidently start the oven or the self-cleaning cycle. Try pressing Bake and Broil Hi/Lo together for 2 seconds (or a bit longer). SF should appear in the display. Then press Self Clean and Start. (When you press Self Clean the LOC message should disappear.)
Manuals for most GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click Submit. The direct link to the manual for the JTP18WWWW is: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981140017.PDF .
I hope this helps.
Jun 02, 2011 | GE Profile JTP18 Electric Single Oven
F9 Error during self cleaning cycle
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 31, 2010 | Ovens
. THE MESSAGE APPEARED WHILE I WAS CLEANING THE
F1:-4 Runaway Clean Lower oven Check oven temperature sensor, replace if necessary
Nov 09, 2009 | Maytag Gemini 30" Self-Cleaning...
Self cleaning oven
Unplug the power cord for few minutes. then plug it back to see if the light still keep coming.
then do this:
Check if you have it in the lock mode.
Press bake and broil pads together for 2 to 3 seconds until SF shows in the display.
Press the self clean pad, display will show loc off or loc on.
Let me know if it clear the fault.
Good luck from : Prince P
Jul 25, 2008 | Kitchen Ranges
Maytag Error Codes:
Jun 27, 2008 | Maytag MER6769 Gemini Electric Kitchen...
Self clean light blinks when you turn oven on (oven does not work)
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
Nov 26, 2006 | GE JGBP26 Gas Kitchen Range
Kitchen Ranges Logo
203 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
