Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag 6500AWQ When in the spin cycle it sounds like a bearing is getting a little noisey. What bearing could this be ?
  • 196 Answers
The outer tub bearing. This bearing is under a lot of stress and tends to wear out. Check and see if there is excess play in the drum. Move the drum all around. Also if you remove the back panel plate you can access the main pulley. If this pulley has any side-to-side or top-to-bottom play then the bearing is bad
Posted on Jan 15, 2008
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
spinout bearing bad if noisey in spin only whole tub must be repaired
Feb 16, 2013 | Maytag Bravos 3.8 Cu. Ft. Washer
Washer is very noisey while on spin cycle like a bad wheel bearing on a car.. but no error codes?
Very sad to say but i imagine this will either be a trapped item such as bra wire caught in the drum or if it sounds like Gatwick airport when it spins it's probably your bearing...can be very expensive to repair. You cannot buy a seperate bearing you have to get hold of a rear tub and drum which depending on where you go could set you back £600ish pounds.
Nov 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Jan 25, 2010 | Maytag Washing Machines
Sounded like an explosion in washer busted enter door and tub edg
when you grab your inner tub is their slop in its movment.if so it is the bearings and junk it lest you have a service about 400 to 500$
Dec 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Noisy spin cycle
The spin bearing is the culprit. Water works down through the tub seal onto the bearing.
Jan 15, 2008 | Maytag MAV8557 Top Load Washer
Maytag PAV2000
Its possible that the machine is not reaching full speed during spin. Check to see if the belt is slipping and that the thrust bearing pulley turns freely. When in the spin cycle the thrust bearing compresses the brake directly above it. If this brake is hanging up even a little the machine cannot reach full speed. The diagram on the right shows the thrust bearing assy. and brake.754307c.gif
Jan 14, 2008 | Maytag Performa PAV2200
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
104 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
