Question about Sony Playstation 3 (PS3) Console
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we can hear the sound turn on...but we have no picture.....is there anything we can do? we have already tried holding down the button for the 5 seconds and everything..but nothing helps with the picture. Is there anything we can try?
    Novelist:
  • 149 Answers
Try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Posted on Oct 28, 2009
SOURCE:
Over heating
If it's constantly overheating I would start by checking to make sure you have the correct fluid amount. Then I would verify that it's coolant and not just water. After that I would run it and see if the thermostat opens once it starts to get hot. If not it may be bad and have to be replaced. If it does open, then I would check to make sure your fan(s) are kicking on.If the fans aren't kicking on it could be a relay or it could be the fan itself. If the fan clutch went out then it wouldn't be able to cool the way it's supposed to. If all that checks good then I would be suspect of the water pump or a plugged heater core.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Dec 02, 2013 | Toyota Passenger Cars & Trucks
My PS3 powers off while playing a game after about 15-20minutes. after i turn it off and start, it works for another 15-20 min. Why is this happening?
It is probably overheating. Make sure you have you console in an open area. Do not put it into an entertainment center slot with the proper airflow. There should be room for air to circulate in the front and the back. Do not close any door while it's running. All you do is circulate warm air that only gets hotter around the console. If needed, use a small desk fan to blow air directly on the console to keep the temperature in check.
Good luck.
Apr 26, 2011 | Sony Playstation 3 (PS3) Console
I have the older PS3 and the games picture are starting to get distorted.
I also have a "fat" PS3. Unfortunately, it seems that many of these units are starting to kick the bucket.
The most you can hope for is the distorted picture being due to bad cable connection (which I would check) or overheating. In the case of overheating, its possible you can open the ocnsole and apply some thermal past to the heatsinks, but I wouldn't try this unless you are comfortable with such procedures.
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
My PS3 tries to turn on... but won't
Generally its an overheating Problem send it back to Sony to fix
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
PS3 overheated - won't read dvd
It's a simple problem, your ps3 has overheated, so you need to get a fan, or get the once inside the ps3 fixed, if that doesn't help just send it to a repair station, either once is simple and doesn't cost mega money.
Nov 21, 2009 | Sony Video Game Consoles & Games
PS3 Loud Fan Noise
It sounds like it needs to be cleaned, just blow some compressed air into the fan area, unless you can actually get it opened, then that would be better.
Hope this helps!
Aug 25, 2009 | Sony Playstation 3 (PS3) Console
After turning on my ps3 for like 15-20 minutes,
it is turning off? if no, then no overheating.
fans will be on while you're playing, it's normal.
check the game position and place, there are something blocking the air?
leave some space around to allow the ps3 to "breath".
Aug 14, 2009 | Sony Playstation 3 (PS3) Console
Inverter fan kicks on after turning on a light bulb
the inverter fan just kicks on to keep the system from overheating. Its perfectly normal.
Jul 24, 2009 | RoadPro RPPI-2500W Inverter
2004 dodge stratus coupe Fan not kicking on while idling
Radiator cap is bad . It's flash bolling out of the radiator into the coolant reservoir ,take an have it pressure tested .
Jun 24, 2017 | 2004 Dodge Stratus
Playstation turning off?
The PS3 turning off with a flashing red light means that the console is overheating.
Make sure the fan (which is at the back) is not blocked by anything, the room your in is ventilated and the PS3 isn't in direct sunlight.
If this still doesn't work then you can buy a more powerful cooling fan for your PS3 or i've heard just aiming a battery powered handheld fan at the back of the PS3 works
Feb 15, 2009 | Activision Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
135 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
