Question about Epson Perfection 1660 Photo Flatbed Scanner
Scanning slides -
I have not had this problem in the past, only recently. When I scan slides, they will start out OK, then after a couple passes, the scanner will produce a 'negative' instead of a photo of the slide. I am trying to save them in a file to transfer to a CD. Can you assist? I thought of re-installing the software.
    Genius:
  • 2,985 Answers
Do try reinstalling the fotware this is where the trouble lies.
Or
Save the scans and in a suitable photo Editor revers the image Neg to Pos
Posted on Dec 31, 2007
After 2 yrs unused have decided to run in new dell
Did you plug in the scan unit and then installed the software?
If you did you will have to unplug or turn off your scanner then uninstall your software.
Reboot and the with the scanner turned off reinstall the software. If the install asks you to plug in your scanner, turn it on. If it asks you to reboot, then reboot. After rebooting, turn on the scanner then start the Easy Scan Utility. This should work.
It worked for me.
Jan 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Edge Of Scan Overexposed
If the slides are ok , and not overexposed themself, brown discoloration on the side means a problem with the scanner lamp.
Oct 05, 2008 | Nikon CoolScan V ED Film Scanner
Is there a manual that shows how to scan slides
Here is the support site for your scanner:
Canon LiDE 600F Support
Under the Drivers & Downloads there are a couple manuals. The Quick Start Guide, which is a PDF file and the On Screen manual which is an exe file. The PDF will open right up. The other you will need to download the file to your desktop and when the download completes you need to run (double-click) the file to install it.
Note: This scanner does not support scanning of Mounted slides. (See Footnote #5 on Page 9 of the Quick Start Guide.)
You may be able to unmount the slides carefully and follow the instructions for scanning film. You might try that on a less desirable slide before unmounting them all. Just a suggestion.
Thanks for using Fixya.
Sep 29, 2009 | Canon LiDE 600F Led Printer
Can't scan slides on Epson 4490
Please make sure that the option cable on the back of the scanner is seated properly.
You may need to trash and re-install the drivers.
To get the most recent driver compatible with your operating system, please log on to epson.com and go to the drivers and support page.
Apr 28, 2009 | Epson Perfection 4490 Photo Scanner...
HP Officejet 6310x -when I try to scan it states "no scan option"
You don't have to re-install, just go to the HP Solution Center - Settings - Scan to Setup - and drag the applicatiosn you want the option to "Scan to", click on OK, and yer ready to go.
Feb 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Scanning
If you are getting this message when you are trying to scan from the All-In-One on a windows operating system.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Sep 28, 2008 | HP Photosmart C6280 Printer
Scanning
This message will come up when you are scanning from the Stand alone printer not from the computer.
If the software is sucessfully installed in your computer,
Then you should have a icon which says HP Director / HP Solution Center (If not Goto> Start> All Programs> HP and then you will see them
Open HP Director/Solution Center and try scanning from there, It should scan from there.
If yes then go to settings> Scann Settings> Scan to setup> There you see an option which says Front panel Destination list> Click that and there you see a options says Restore Defaults> Click that> then Apply and Ok> And close all the indows and try scanning from the All-In-One.
If it does not work then try the steps bellow:
Go To:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
Sep 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Scanning slides with anoscan 4200F
have you tried checking for a firmware update from the manufacturer?
Oct 13, 2007 | Canon CanoScan 4200F Flatbed Scanner
Noise during scanning
Not really these are sealed units - nothing to repair. If it works grit your teeth and bear it. If you open it up and try to lubricate the offending parts the chances are you will kill it dead.
Sep 19, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Feb 04, 2007 | Epson Perfection 1250 Photo Flatbed...
Epson Perfection 1660 Photo Flatbed Scanner Logo
143 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
