Question about Audio Shelf Systems
Spectrum AIL495 keyboard stoped producing sound
How to make the keyboard have sound
0 characters
1 Points
What is a output ic
The audio output ic generates the audio to your speakes producing sound.
Apr 30, 2012 | JVC HX-C6 Shelf System
It turns on, plays for a second and then it produces a "thump" sound through the speakers and then goes silent. And is completely dead.
The thump sound is being made by the capacitors in the power amp discharging as the power is loss, and is not a symptom of the problem. Have you checked all internal and external fuses?
Mar 01, 2011 | Aiwa NSX-AJ310 Shelf System
How can i put my tv threw my stereo i have yellow white and red in the back of tv and in the back of the stereo i have 2 white 2 red and 2 black pls can you help me
Since we're most concerned with the stereo sound, disregard colors and read the silkscreened legends for the connectors.
However you would be better to get your TV-related audio from the cable box in the same way. TV electronics is on the lo-fi end of the quality spectrum. And its own volume control may affect the output. If the TV has a setting to make the output FIXED, select it so you can turn the TV volume down and let the real speakers do the audio job.
Whichever you choose...
Connect Audio L and R Out from the TV to any convenient input (AUX?) on the Technics.
Apr 10, 2010 | Technics SC-EH780 CD Shelf System
Very poor sound when i play my record player
What kind of record player? Most modern equipment doesn't have a phono preamp to boost the minute signal produced from the phono cartridge to a Line level so guess what, they don't play phono correctly.
Dec 26, 2009 | Sharp CD-C2900 Shelf System
SoundDock produces only harsh crackling sound
Yeah i had that same problem. You know the chord? The cord you plug in from outlet. The square cord you plug into your speakers.. yeah the "DC outlet" is supposed to be UP. if you have it the wrong way in there it wont work and will make a crackling sound.
Apr 30, 2008 | Bose SoundDock Digital Music System for...
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
No sound
MCM720 is one of the biggest CRAPS that Philips ever produced. if it is low volume, it produces 1250 Hz background noises that are real pain in the a... . If you go up with volume, amplifier goes into temporary shutdown. Just return and get money back and buy something better. Borut
Aug 08, 2007 | Philips MCM720 Shelf System
No sound
i have got the same sterio with the same problem, technics are usualy the best around but this sterio is an absolute waste of £500 my solution is to just wire a different amp up to the old one
Jan 08, 2007 | Technics SCEH790 CD Shelf System
Audio Shelf Systems Logo
108 people viewed this question
Top Audio Shelf Systems Experts
Are you an Audio Shelf System Expert? Answer questions, earn points and help others
