Question about Maxtor (6L250R0) 250 GB Hard Drive
Failure Suddenly my maxtor 250 GB external USB drive started showing 0 byes free and 0 bytes used, seems to be a problem with drive card - 302007101 (SABRE PATA/ROHS) Any luck to get one ?
3 Suggested Answers
  • 29 Answers
SOURCE: maxtor 4 mini usb 250 gb not recognized
find a DR software to recover the data,if the data is very important,then you'd better go to a DR company.
Meanwhile,if you want to use the dr tool,you can use the HD Doctor for Maxtor,but u will spend some money
Posted on Apr 14, 2009
  • 6831 Answers
SOURCE: maxtor one touch external hard drive suddenly
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Posted on Sep 29, 2010
  • 36 Answers
SOURCE: how can replace the damaged external 250 gb maxtor
Contact the seller for assistance in warranty replacement. They will either handle it themselves or refer you to the manufacturer for assistance.
Posted on Nov 13, 2010
0 characters
1 Points
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk please help!
Aug 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
External 500gb hard drive not readable
Check the partition size in Disk Management (if running Win7 - download a free Partition Manager if not) and see if the system is seeing the partition correctly. Seagate has recovery software available on their website but you may just have to repartition and reformat.
Apr 25, 2010 | Seagate 320GB Portable External Drive ...
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
SimpleDrive 160 GB drive is recognized by XP, but cannot access. Have tried on 4 computers. Properties show 0 bytes size and 0 bytes free. Can't even Format Drive. This happened after interrupting an...
The drive was damaged during the interuption. This has happened to alot of my flash drives and there is not way to fix it. You can, however, replace the hard drive in the case. Open the case and you will see a small laptop hard drive (that's all it is), purchase a new replacement and throw it in there.
Oct 04, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Folder structure showing 0 files on external HD -after powersurge
You may use data recovery software to see if you can rescue the files on your external HD.
It may unable to recover all the files, but at least most of them.
Sep 27, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
I can't open the files on my SimpleDrive 500gb external hard drive. It only shows the one file, $AVG8.VAULT$, which is only 24 bytes, but Poroperties indicates it has 112 of 465 GB of Free Space.
The file you mention is used by AVG antivirus. Probably for quarantine purposes and so on.
You will find that file on all drives if you are using AVG.
This should not affect any other files on the disk, unless they were infected with a virus and have been placed inside the VAULT file.
You really need to use AVG to access the file and its contents if possible.
Apr 16, 2009 | Western Digital 250GB MyBook External USB...
It appears it is not being recognized and mounted. Try running the add new hardware wizard if it isn't in your device manager already.
Feb 12, 2008 | Maxtor OneTouch II external hard drive...
Maxtor (6L250R0) 250 GB Hard Drive Logo
60 people viewed this question
Top Maxtor Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Maxtor Hard Drive Expert? Answer questions, earn points and help others
