Question about Jenn-Air JFC2087HRP Side by Side Refrigerator
Jenn-air refrigerator I came home and the power on the fridge is completely off, checked the house fuses and they are all fine. Tried unplugging and putting back in but nothing.
    Sergeant:
  • 263 Answers
Check the outlet power to see if there is power may be the outlet because the outlet conections are like fuses and some times they are burnd so check the outlet if no power check the wires attach to the outlet
Posted on Dec 30, 2007
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
Jenn air side by side completely powered down. No clicks no noises just simply was working at 5am then dark as night at 7am. Checked power, flipped circuit, tried reset, tried manual on/off. Nothing
If there were no lights on inside I would have to say a connection from the power source to the fridge has been rattled loose. But if the lights were on and nothing was running, you may have a compresser problem. I would pull the frige out and pull the back bottom panel off and look for burnt or loose wires following the plug wire into the fridge. If the lights are on when you plug it in and you have the back off, put your hand on the compresser, if it is not vibrating and is very hot it is done fore and needs to be replaced. If it is cool and the lights are on I could check the connection on the thermostat inside the fridge. If it is clicking and nothing is happening the t-stat contacts may be stuck open Good luck
Sep 06, 2012 | Jenn-Air Refrigerators
Jenn-air built in refridgerator
Nothing not even the lights come on? A power surge might have blown out the breaker on the fridge.
Apr 04, 2012 | Jenn-Air Refrigerators
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Jenn air refrigerator jfc2089h temp indicator lights both show off
hi there,
sounds like you may have tripped the house breaker. can you unplug the fridge for about 1 minute. in the meantime, check the breaker and flick it on and off. then plug the fridge back into the wall. if you still have no power, it could be the compressor or the motor. i would have a tech take a look at it.
Oct 01, 2008 | Jenn-Air Pro-Style JFC2089H French Door...
JCD 2389 GES Not cooling
Yes. I would suggest the control board is possibly damaged.
Model jcd2389ges JENN AIR SIDE BY SIDE REFRIGERATOR Parts
This is not the only place to look, but it is where I would start.
Dec 19, 2017 | Jenn-Air JCD2290HES Side by Side...
Refrigerator stopped working, freezer works fine
I turned off the refrigerator and left the freezer door open so the coils and the vents could thaw out. The cold air was not getting to the refrigerator section because of ice blocking the vents.
May 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Jenn-Air JFC2087HRP Side by Side Refrigerator Logo
134 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
