Question about Panasonic MC-E583 Bagged Upright Vacuum
Change belt How do I get at the roller to preplace belt
  • Libby100 Dec 29, 2007
    Panasonic MC-469
    President:
  • 1,673 Answers
To get to the brush roll, you have to take the bottom part. There is no belt, the brush roll motor is part of the brush roll.
Posted on Feb 05, 2008
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
How to change the belt on a Eureka powerline limited edition vacuum cleaner.
The belt is directly connected to the brush roller. Remove the brush roller cover. Pull out the brush roller. Remove all carpet strings. Change the belt.
Jun 11, 2011 | Vacuums
The roller brush will not turn. The belt is not
Sometimes the belt can stretch cause the roller to not turn. Also make sure the roller brush is free of any debris.
Use this link to access your vacuum to change belt or clean the roller brush.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 27, 2010 | Hoover U5068-900 Sprint Upright Vacuum
The brushes are not spinning. I get suction, but the brushes don't turn.
Your belt has probably broken. Here is a link to the belt you need:
Dyson DC17 Belt
And here is instructions on how to change it:
1. Loosen 3 screws from bottom plate using flathead screwdriver or coin edge and remove it.
2. Wiggle roller until it pulls straight out.
3. Squeeze new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
Nov 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Roller quit working - but belt still attached
try turning the rollers by hand,,, if they turn,,, can you hold the rollers and still turn the belt,,(dont turn on the motor) ,,, if so,, its the belt sliping on the rollers
and the fix is,,,change the belt for a new one,,,
i hope this has helped you
Oct 26, 2009 | Hoover Vacuums
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
No manual
Take the hood off of the unit, and remove the brush roller and belt. Wrap the new belt around the shaft of the motor and slide the brush roller inside the loop of the belt. Use the brush roller as leverage to stretch the belt out and slide the brush roller back into the roller housing. Once you have it installed correctly, make sure the roller and belt are free, by spinning it by hand. If that belt is pinched it will just burn it up when you turn the unit on.
Good luck
Oct 25, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Chaning the belt
there is a plate on the underside covering belt and beater roller
2-3 screws to secure the plate
then withdraw the roller
put new belt round roller
insert roller
pull belt around motor pulley
reinstall plate
Oct 05, 2008 | Hoover Commercial C1403 Bagged Upright...
Roller and Belt
I have had this vacuum for about 5 years now. You need to change the belt every 6 months. Walmart sells a bag of 3 replacement belts.
May 27, 2008 | GE 106766 Bagged Canister Vacuum
Panasonic MC-E583 Bagged Upright Vacuum Logo
169 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
