Question about Motorola Mobility RAZR V3
DISASSEMBLY razr V3
I want to change de keypad but I havening problem to release the flex
how can I to disassembly.
http://65.6.166.218/test/motorola/f1.jpg
http://65.6.166.218/test/motorola/f2.jpg
http://65.6.166.218/test/motorola/f3.jpg
http://65.6.166.218/test/motorola/f4.jpg
http://65.6.166.218/test/motorola/f5.jpg
Thanks in advance
  • 77 Answers
The hinge doesn't disassemble ... The whole top half and the bottom frame are all one unit.
Razr's aren't built to be taken apart.
Posted on Dec 31, 2007
My phone's keypad just lights up for few second the moment i turn it on then turns off again without a light on the screen .can you help me fix this problem?my phone is a razr v3 model.
Hi,when a Razor v3 has a light issues isuaully caused by the flex of the phone.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone and the light.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Aug 17, 2011 | Motorola Mobility RAZR V3
My screen display is upside down on my razr V3, please help fix
The reason the display on your phone is upside down is that there is a problem with the flex of your phone.
The flex of a phone is the link that connects the screen to the keypad. It is the mechanism that makes the phone able to be flipped.
to fix the flex of a motorola razr V3 is quite uneasy, unless you have the basic skills required to fix it.
get the appropriate screwdriver,
unscrew the phone,
carefully detach the screen from the keypad and adjust or replace the flex. carefully couple back the phone and it will be okay once again.
take care
Jun 12, 2010 | Motorola Mobility RAZR V3
My phone pad doesn't respond??? The only button
Your motorola RAZR V3 cellular phones has a solution,Most V3 versions of phones have one specific problem.which is flex problem.when ever your using your phone and your keypads does not respond,No that is the flex cause the flex is connected from the screen to the keyboard.so you can change the flex of your phone.
Jan 11, 2010 | Motorola Mobility RAZR V3
Motorola razr keypad not working
Generally, the keypad does not need to be changed. Usually, one of the flex connectors in the flip (screen/camera) portion of the phone is loose, dirty and/or corroded (maybe from water, sweat, wear, trauma, etc). This is relatively easily fixed by a semi tech savy consumer. You will need a size T5 star driver (and possibly a T6) and a small screw driver, along with some rubbing (isopropyl) alcohol and some Q-tips.
For more information on servicing your phone, you should do an internte search for RAZR dissassembly http://www.google.com/search?sourceid=navclient&aq=t&ie=UTF-8&rls=GGLJ,GGLJ:2006 -45,GGLJ:en&q=razr+v3+disassembly and you'll get lots of hits including videos like this: http://video.google.com/videoplay?docid=-5120755491924318860#
When you have the top case dissassembled, the connector with the black patch on the top is likely loose. Clean the connections thoroughly with alcohol and a Q-Tip and reassemble. If it doesn't work, or only works partially, another cleaning may help (I had to go in twice).
http://www.celtnet.org.uk/mobile-phone/disassemble-motorola-v3-3.php
Jun 24, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Keypad backlight does not come on
Change the keypad flex connector. If still don't come the light you need to change some parts near flex connector.
May 19, 2008 | Motorola Mobility RAZR V3
RAZR V3 FLEX
you need to take the phone to a mobile service center to have them reflash the flex file into your mobile.
May 01, 2008 | Motorola Mobility RAZR V3
RAZR V3 Keypad
did you tried to change the flex of your phone? if not, try to change it.
Apr 29, 2008 | Motorola Mobility RAZR V3
Motorola razr freezing
your phone problem is the keypad flex of your phone'
you can fix it by replacing the keypad flex'
motorola dealer has the keypad flex'
ask for a skilled cellular technician to re-place your keypad fle..
i hope it will helf to your prob...
Jan 07, 2008 | Motorola Mobility RAZR V3
Tries To Come on, But Screen Will NOT Light Up!
hi there.
the problem your having is caused by a ribbon that connects the screen and the mainboard in the phone.
the ribbon seems to have either come loose or detached.other than that being a problem it will almost certainly be a screen issue where the lcd has burnt out.
but in my professional opinion it will almost certainly be a ribbon issue
Dec 09, 2007 | Motorola Mobility RAZR V3
Keypad Razr V3C
you will have to search online for that or try www.motodev.com and see if this site helps you.
Sep 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
321 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
