Split wall-mounted air conditioner
This model is a 24000 btu. it calls for a power source of 240v/60Hz/1 phase. Is this to be ran on a 110 or 220?
  • 236 Answers
You can use 220 volts for this unit.
Posted on Dec 29, 2007
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
Outside unit turns on and runs for a long time by itself then shuts off. Does this all day an night long. Notice this after a circuit breaker tripped. Not breaker to unit though. Other parts of house.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other Air Conditioning Repair help. Check us out online.
Jul 25, 2016 | Celiera Celi 24000 BTU Ductless Mini Split...
Mr. silm 42000 btu air conditioner in door working outdoornot working
mr. slim air conditioner good brand. wall type or casset type (Roof model)?..
1) may be your control processing unit (PCB) damage.
2) Refrigerant gas leaking. low pressure switch off.
3) Compressor not working properly.
4) This is 3 phase model may be Ac power not correct.
my opinion call Service person.
Mar 22, 2011 | Mitsubishi Heating & Cooling
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
Require specifications for an Emailair split level air con model CWS 034A
Capacity which normaly known as Horse Power
or RA rating
The voltage input
Ampere ratings
voltage phase ex. (single phase or three phase)
Type: Split type
since it is split type there are several classification(wall mounted, foor mounted or ceiling mounted)
Oct 31, 2009 | Heating & Cooling
Heat pump doesnt turn on when calling for heat
Make sure your power source is still supplying power. Breaker box, maybe you have another too many appliances hooked up to same circuit? If that does not work, get advise from your local distributer before having a small appliance tech charge you for the issue.
Dec 05, 2008 | Friedrich YL24J35D HEAT COOL 24000 BTU 230...
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
