Adding second drive to system
Hi
Basic issue I hope.
my old PC (Windows XP) died so have invested in new PC.
I have recovered the old Disc Drive (Samsung SP1614C) which has all my programmes on and the old XP OPS in a partition.
Have installed into new PC which has single drive ST350063 OAS SCSI (Seagate) and straped them together using the connectors in the PC.
The Vista Home premium will find the disc under the device manager but it has no letter assinment and cannot be found in explorer.
There is one DVD RW drive and four external drive outlets (USB) so D,E,F,G & h are used.
Basic problem can you help?
  • jimbo1754 Dec 29, 2007
    Thanks Tom
    Its in the BIOS
    Jumper? No not fitted.
    Note on top of old drive says
    Master/Slave jumper not required for SATA.???
    I have 8 pins on the Samsung though but no instructions as to which if any are to be used.?
    Cheers
    Jim
    Thanks Tom
    Under Computer Management / Storage / Disc Management the added disc is visible.
    It's status is Healthy (Active, Primary Partition)
    I have managed to reassign the DVD and USB drives with new values to allow the renaming of the new disc.
    However, when I try to change the drive letter by right clicking over the name the only option I am given is to view properties.
    Right clicking over the right graphical area only shows the options but they are greyed out.
    Genius:
  • 1,601 Answers
Did you change jumper on the old drive to slave? Also check BIOS and see if has it listed.
Posted on Dec 29, 2007
I need to download windows xp to install on my 2nd computer
You cannot download Windows XP unfortunately. You may be able to purchase a copy on Ebay. You will need your own installation key which should be on a sticker attached to your PC.
May 11, 2014 | Microsoft Windows XP Home Edition
We need a restore disc for a Compaq Pressario 6000. Seem our hard drive is having an issue.
You will need to contact Compaq support to order a recovery disc for your machine.
Jul 17, 2008 | Compaq Computers & Internet
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
How to reformat a laptop using the F9 function?
So my questions would be are you attempting to restore your PC to factory settings? or put a new Operating System on it?
If you are trying to restore to the way you got it, you probably have a recovery partition on your hard drive. If this is the case you are going to want to restore to your recovery hard drive.
If you are trying to put a new operating system on your PC then you will probably want to recover to the non recovery hard drive.
The other option to use the entire hard drive will give you more space on your PC to use, but will wipe out your recovery partition. Hope this helps.
If this isn't making sense try taking a picture of your partitions and posting up here so we can give you better advice.
Oct 28, 2012 | Computers & Internet
I found my old U3 flash drive that is password protected but when I plug it into my pc it won't boot. I can see some basic files but none of my data. I can't get in to remove password protection. It ver....
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards,
USB Memory Drives
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
Support IDE/SATA/USB Hard Drives, memory cards, USB Memory Drives
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Apr 13, 2011 | Verbatim Store n Go U3 Smart Drive USB...
Friend bought used Gateway 1200cs w/win xp and no disks, she wants to put new HDD in and I need to make a disk to re-install windows or copy it to a partition. how to?
Some HDDs come with a cloning software - get that. Then you won't need to redo the operating system. However, if you have the original operating system disc, it has provisions to create another partition, but you want to install a new HDD. If I understand you correctly, she wants her old data in the new HDD - that's a separate issue. If I were you, I would just install the new HDD along with the old HDD together and have the old HDD run the operating system.
Dec 22, 2010 | Microsoft Windows XP Home Edition
I a dimesion dell pc and did a system repair and now I recovered all my old data and now the sound will play I tried adding driver
System repair just rewrites the Operating System and registry causing software to act funny afterwards. I suggest since now you have access to your data back up all your data into a thumb drive, cd ,dvd or external hard drive. Reinstall Operating System(windows xp). .here is a site to show how to do it
http://pcsupport.about.com/od/operatingsystems/ss/instxpclean1.htm
hope that helps
Feb 28, 2010 | Dell Dimension 3000 PC Desktop
Computer wont start up...
It means it cannot find it's operating system or windows to start. When a PC boots it checks for boot devices, usually the floppy, then cdrom, then hard drive, if there is a disk in the floppy or if your pc is set to boot from cdrom and there is a disc in it - it will say OS not found.
The second possible cause is something has happened to windows - either the hard drive has failed or windows has lost it's startup files. If the drive appears to be normal and chatters slightly on startup ( a light clicking noise) then possibly running the original windows install disc and reinstallin windows should fix the problem, on 98 or ME you can re-install, on 2000 or XP try the recover/repair option first.
Oct 26, 2009 | Computers & Internet
Everytime I switch on my Compaq Presario V3000, it displays Error 0200 Fixed Disk error. I will switch off and switch on the second time, then it will boot successfully. Pls advise how to resolve this...
hi,
Well, i think you have a corrupt windows problem. Try to boot with your windows xp cd in the drive. A screen should come up and you want to repair windows xp please read the following. repairing xp
Replacing the hard drive can be a second option and is not at all difficult, but then you have a brand new (empty) disk drive, and you have to reload all your software.
There are companies that specialize in recovering files from broken disk drives, but it is very, very expensive.
I apologize if it happened to you.
best regards,
Jazerblue
Aug 28, 2009 | HP Computers & Internet
Computers & Internet Logo
345 people viewed this question
Alun Cox
David Payne
David Payne
