Black muck My LG top loader leaves particles of black muck after a wash. Trying to clean the machine just seems to produce more. What is it and how do I get rid of it? Thanks
Bob Gemmell
  • 209 Answers
SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Posted on Sep 28, 2007
SOURCE: lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Posted on Dec 10, 2007
  • 734 Answers
SOURCE: Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
  • 15 Answers
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Posted on Mar 10, 2009
jan mczeal
  • 632 Answers
SOURCE: Hi my LG 8kg top loader washing mashine says UE
UE code means an imbalance error. Either the load is too small, the appliance is tilted, laundry is gathered to one side or a non distributable things are put into the drum.
Make sure the unit is placed in level location and distribute the load evenly inside the drum. Do not load the unit with on-distributable items.
Posted on Oct 19, 2009
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
0 characters
1 Points
We were op testing this machine when in the middle of the rinse cycle the lights for door and wash started to blink. Can anyone help? It came with a CDROM but we don't have access to view said manual.
One likely reason--the washer filter is clogged. On my LG large front loader there is a removable door on the bottom front panel of the machine. It should be cleaned once a year. I didn't know that. It was full of disgusting mucK. Just pull out the black rubber drain tube which has a plastic plug. It may drain a gallon or two of evil-smelling yak, so be prepared! clean out the filter, and it should work just fine.
Oct 21, 2015 | Washing Machines
How to get rid of black residue from lg washing machine
The black residue indicates a mould problem. There seem to be a lot of people reporting this problem on the LG washing machines on numerous forums. Since you are dealing with mould you should exercise proper precautions, including wearing a mask, so you do not breathe in the mould. If mould gets into your lungs, you will never be able to get rid of it.
To clean up the mould use plenty of bleach. Make sure to remove the dispenser door to get at the spots where the mould tends to build up. To prevent it, leave the washing machine door open after every wash.
Aug 13, 2014 | LG Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
LG fuzzy logic top loader leaves black marks on white. Happens when doing a large wash-eg; blanket -it looks awful. I'm thinking the insides might need cleaning? How is this done and with what product
If this is moldy looking you should use 1 cup of bleach in the drum with no clothes on the longest wash cycle with the hottest water. But I believe this is oil from the drive train and the seals on the bottom of the drum are going bad. When you wash something heavy like the blanket, it leaks.
Nov 25, 2013 | Washing Machines
Towels smell sour. while cleaning noticed small "hole" (factory made) in bottom of boot in front of three "notches". seems like a drain hole? stuck q-tip in there and stinky black muck discovered. ran...
I think you are talking about the door gasket. Use a mixture of bleach and water in the gasket and also in the drum. Most front load washer are notorious for mold and mildew. Run the washer in a rinse cyle to clean drum. Also clean your drain filter.
Jan 06, 2010 | LG WM2688H Front Load Washer
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Make sure you are washing at the correct temp, and that you have the correct prog selected for what you are washing. and that you have suficient powder and or detergent in. Check to see if the water is getting hot, because if it is not , then the heater may not be working, and then your clothes will not be clean.
Hope this helps with your prob.
Plz rate my solution.
Jan 03, 2009 | LG WM-2277HW Front Load Washer
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Sep 28, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
