Question about Fellowes Shredmate Shredder
Fellowes Shredmate Cross Cut Shredder
Shredder stopped working.
Found a minute switch on the side, under the unit and the shredder works when this switch is kept in so the motor and blades are working.
Spent ages finding a way to separate the top and bottom sections. There's a 7th screw under the bar code label!!!!
I suspect the automatic sensor / switch has failed inside the feeder slot?
  • artyman Dec 29, 2007
    What a plonker I am!!!
    The shredder MUST be placed on top of the paper bin provided as there is an unobtrusive metal "arm" welded to the bin's left side which keeps the micro switch engaged.
    I had been testing the shredder removed from the paper bin.
    All is well now.
  • Anonymous Mar 26, 2014
    Top single feeder works but not 100 sheet auto feeder
  • 579 Answers
Learn something new every day!
Posted on Dec 31, 2007
Why does my shredder run when there is no paper, but stops as soon as I insert paper into the slot?!
You may have paper stuck in the blades and its jamming.try forward and reverse to free it up or you may have the head unit on the can faced the wrong way. Pull it out and turn head around and than try. I know on some shredders if the head unit does not fit on the right way it wount push down the safety switch and it wount run.
Mar 02, 2015 | Omnitech 10-Sheet Micro-Cut Shredder
I have a Royal Mp220 paper shredder the motor hums when you put the paper to the blades it doesn't shredd the blades do not turn .
To begin with I'll explain that I'm not familiar with your shredder at all, but what you describe might be the same thing I've seen on other shredders. Many actually have a second hidden switch which serves as an interlock to make sure the unit is properly seated in the catch basket. In most cases its located a corner and the catch basket actually has a small shelf to press the micro switch in that location. I'd suggest you examine the bottom side of the shredder to see if you can see a small switch that also needs to be pressed.
Apr 24, 2014 | Royal Office Equipment & Supplies
Ccs/5 shredder wont power on
Do a very thorough inspection of the cutting blades. I have found that just a shred of paper, that one would think would not be a problem, can in fact make your shredder act as you describe. How old is it? Depending on age & the heavy usage you say it has had.... it could very well be good old made in USA obsolescence. Wish I could tell you more. Without a multi-meter;(Ohm Meter). & manual to know what power is getting from point A to point B I cannot advise beyond this. Sorry.
Dec 25, 2013 | Achiever CCS5000 Shredder
The shredder motor will run in reverse only. When the function switch is placed in the forward postition, a red lamp illuminates indicating a motor problem
Welcome to fixya
I have a solution for this, Please follow up with me if you need more information. Content
There is paper stuck inside the shred blades, unplug your unit and remove the paper. You will find that your shredder works in normal direction again. IE SHREDDER EXPERT
More information is available in the comments
My name is Bruce
Jan 21, 2011 | Fellowes 3202HS Shredder
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    Royal 85x crosscut shredder stopped working
    Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
    If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
    May 25, 2010 | Royal 85X Shredder
    My paper shredder stopped working
    First things First...UNPLUG THE UNIT. It sounds like it has been fed too many pages at one time. You may also want to dump any shredded paper so there is plenty of room for the shredder blades to pull in the paper. If the paper catcher is too full the blades can grab shreds from the bottom and stop the blades movement. Just be careful. Shredders can be dangerous.
    Jun 01, 2009 | Office Equipment & Supplies
    Shredder is very sluggish
    Yes they require lubrication
    You can buy shredder oil from lots of office equipment suppliers
    To see if it helps spray some WD40 (using the plastic extender) into either side of the opening where you normally put the paper.
    Switch the machine on to run continually and give the blades another good spray
    This should loosed up any dust which has gathered
    If the machine picks up its pace then go buy some real shredder oil and use it before every operation
    Do not go mad with the amount you apply but dont skimp
    May 31, 2009 | Memorex Paper Shredder
    Powershred 380-c
    Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
    Jun 16, 2008 | Fellowes Powershred 420 Shredder
    I hear about this all the time where I work, unfortunately the motor got overheated and is dead. If the shredder is still under warranty you may want to contact Fellowes and see if there is anything they can do.
    Aug 26, 2007 | Office Equipment & Supplies
    Fellowes Shredmate Shredder Logo
    380 people viewed this question
    Top Fellowes Office Equipment & Supplies Experts
    quennie732
    Charles T Nevin
    Charles T Nevin
    OfficeServiceAjnc
    OfficeServiceAjnc
    Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
