Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
Battery Charge Light not working & can't display battery info
Got my camcorder out the other day in preparation for the wife using it and checked the batteries using the dspl/batt info button - worked fine.
Now I thought I'd switched it off properly but came to use it today and the main large FP70 battery was totally flat so I plugged in the mains supply to check a tape. After a while it started flicking back from play to camera mode.
Now when I plug in either the FP70 or the FP50 I can't get the battery info display or the charge light when i set the FP70 to charge,
I've confirmed the adapter is working by turning the camcorder on with only the adapter connected and it seems to be charging the FP70 as I've left it plugged in then turned the camcorder on and got a read out in the normal LCD display for remaining charge time for both the FP70 & FP50.
  • 3 Answers
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
Posted on Apr 24, 2008
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
I am using my camcorder after 1 year and when i kept it for charging the charge indicator is not working and when i tried to use it without battery through AC source its not working What to do?h
put the battery in
plug the charger in
wait for it to charge
if it doesn't charge get a new battery
if the charger light doesn't work it may need servicing
that's a start
Mar 09, 2011 | Sony DCR-TRV285E Digital-8 Digital...
My battery is not holding charge
ensure the battery is well charged allover again
use the right charger and charge for the allocated duration
when you are not using the camera, remove battery from the panel
then if you charge and dont use your battery for a couple of days please charge again before using as it would have decharged to an extent to avoid disappointment.
if the above don't work, the battery might have gone bad and you may need to request for replacement form your vendor
Jan 09, 2011 | Sony Handycam CCD-TRV65 Camcorder
Have not used it for some time. Have charged battery for a whole day and it still will not switch on? Any ideas?
when you hook the battery to the charger is the charged light comming on.have you a volt meter or a bulb [9 volt] to see if there is any charge in the battery.have you hooked up the camcorder using its mains tranformer to check that the camera is working? if so and it is you may have a circuit protector/fuse gone/blown internally.check the connections on the battery and the charger..hope this is of some help all the best farr64[colin]
Dec 29, 2009 | JVC Cybercam GR-DVP7 Mini DV Digital...
Insignia 5.0 mp hd camcorder. How do I charge the battery?
Make sue the text side of the battery is facing up. Not the pure black side... I was having this problem until I decided to flip the battery around and it worked just fine...
Jan 09, 2009 | Cameras
Not charging?
Please plug the camera charger in AC Outlet and hook it to camera. Check camera power turn ON, works fine? if OK, switch it to Standby / Off mode. Attach battery and check any charging light lit? If yes, leave the camera on charging position for 4-5 hours until its charge light flashs or turn Off. battery is chaged now. Have fun :)
Aug 13, 2008 | Sony Handycam CCD-TRV37 Camcorder
Battery Won't Charge on JVC GZ-MG275
The only suggestion is that it's a faulty battery. You said the camcorder is new, take the battery back, it's under waranty, and get a new one.
Dec 25, 2007 | JVC Lenmar BN-VF707U Camcorder Battery
Battry Mode not working
If where you put the batteries in are corroded you can use a small file or sand paper to clean them up so you can get better connections hope this helps Merry Christmas
Dec 03, 2017 | Sony Handycam DCR-HC32 Mini DV Digital...
RCA prov712 battery will only last 5 minutes
Be sure to charge for AT LEAST 14 hours on the new battery, even if the charger light goes out - it's still trickle charging. It's normal for most camcorders to auto-shut off after 5 minutes, if it's not recording. But if your batt light comes on, the problem is probably with the battery.
Dec 19, 2006 | RCA PROV712 Camcorder
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
190 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
