Question about Magellan Roadmate 760 GPS Receiver
Unit will not acquire the satellite signs
When the unit is turned on it will not acquire a signal. I have contacted Magellan for assistance and they recommend to reset gps and enter the position manually. Still the unit continues to search for signal
  • mcduff111 Feb 12, 2008
    I get no signal from sattelites. I followed all the steps to reset the gps unit but to no avail. I would like to sell my old unit but cannot find anyone that does repair or remanufacture. After speaking with India 3 or 4 times and getting a taste of their customer service I bought a Garmin. I would recommend any brand over Magellan.
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Posted on Jan 30, 2008
  • Michael Tinsley Feb 03, 2008
    MY SOLUTION: After all the above, and my post about upgrading my Roadmate 760 which killed it dead, as in won't boot up, connect to computer, dead with blue screen, Magellan called and stated they are sending me a Magellan Maestro 4210 GPS replacement . After reading the specs I have only four questions:
    1. Will this unit work with the problems I had with the anti-glare shield blocking the GPS signal from my Roadmate 760?
    2. Will the map data be up-to-date?
    3. Since the Maestro 4210 has an integrated antenna, it seems that an external antenna is out of the question. If it can't pick up a signal, then what?
    4. Does anyone want to buy a brand new (still in the bag, never mounted) external antenna that fits Magellan Roadmate or Magellan Meridian GPS units. Bought it same time I was going to update my 760 GPS. If so, e-mail me or leave me a comment.
My brand new 2136T-LM displays my location as somewhere in California. I am in Lewiston, Maine. I drove around the block; according to my Magellan, I am still in California.
You need a lock on satellite signals in order for the unit to know where you are. Turn the unit off and back on, if its the first time acquring satellites for the unit, go outside away from tall buildings or trees and let it sit still while it acquires satellites for the first time. It can take anywhere from 1min-15 minutes.
Sep 25, 2011 | Magellan GPS
I have a Garmin Nuvi 300 model and from last few days its not picking the satellite signals when I open the antenna, it keeps saying searching for satellitie signal. What could be problem & can it be...
Hello there,
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes. If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites. If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal. If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased. If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions. If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites. If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*. If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin GPS
I have a 1475 Magellan GPS which will not acquire the signal. My unit was on for over four hours last night, trying to acquire the satellite signal. How do I solve this problem?
I can understand the problem in the unit, so to over come this problem you have to reset the unit .When you reset the unit surely the unit will it acquire the satellite signal also it show your current location.Follow the steps to reset the unit :
On the left hand side at the lower bottom coner you can see a small pin hole there named as reset .Just insert a paper clip in to the hole when the unit is on.this is the way to reset the unit......
Feb 18, 2011 | GPS
Magellan Roadmate 2000.. No GPS signals
make sure the battery is charged up good, then take it outside and turn it on and leave it in clear view of the open sky for up to 30 minutes to acquire the satellites especially if its been reset.
if that fails, reset the unit...turn it on, then locate the reset button on the left side bottom of the gps and use a paper clip to depress the reset switch...it should restart on its own..take it back outside and let it in clear view of the open sky for up to 30 minutes.
if that fails..go HERE and get the update and follow the instructions..you will have to sign on to the Magellan site before you can download anything.
if you need more help, just post back
bill
Jul 16, 2010 | Magellan RoadMate 2000 GPS Receiver
The unit keeps displaying "acquiring signl" - what does this mean?
Your unit is trying to locate the satellites for location fix. If it cannot acquire the satellites in couple of minutes, you should move to a place where the unit has clear view to the skies.
Dec 26, 2009 | Magellan RoadMate 1340 GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan GPS Pioneer will not hold onto satellite signal
I had the same problem. Found this link
http://forums.groundspeak.com/GC/index.php?showtopic=144134
As suggested at the end of the above thread I left my unit outside for a couple of hours and it suddenly sprang into life. Now it reliably gets a fix in 2 to 3 minutes when I switch it on.
My theory is that because it is only a 2 channel unit it takes hours to acquire a fix when the memory is blank.
The manual says it will keep it's memory for a month without batteries.
So if you leave the batteries out for more than a month, or move it more than 250 miles and then switch it on expect it to take a while to first fix.
Otherwise it's a nice little unit.
Mar 15, 2009 | GPS
Hello i have the garmin 250 i had brought it on the water a few weeks ago and as soon as i got of the water it has a question mark and says aquiring satatiles but never picks up a signal and doesnt work...
Question: Why won't my unit acquire satellites?
--> Answer: There are a several different factors that can cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it is normal for it to take a while to establish its initial position.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take longer than normal to acquire.
  • If your unit has traveled a long distance while turned off or not tracking your travel, it may take a longer period of time to acquire.
  • If your unit has not been used for an extended period of time, it may take a longer period of time to acquire.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, you may need an external antenna.
If your unit is not acquiring satellites, it is recommended that you place the unit in a stationary position where it has a clear view of the sky. In some cases it may be necessary to take the unit outside of your vehicle as certain vehicles inhibit the unit from acquiring satellites. As the unit receives signal from the satellites, it will begin to lock on to them individually until it has acquired enough information to establish your position.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software. You can do this using our WebUpdater program which can be found at the following link:
http://www.garmin.com/products/webupdater/howtoinstall.jsp
Sep 25, 2008 | GPS
Cannot get satelite signal for magellan triton 1500.
Options:
1) Walk outside and give the unit 3 - 5 minutes to acquire satellites.
2) Push the PAGE/GOTO button on the left side of the unit until you see the satellite page and see if you are picking up satellite.
3) If 2 and 3 do not work .. then reload the firmware again.
JG
Aug 22, 2008 | GPS
Magellan Roadmate 760 GPS Receiver Logo
795 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
