Question about Sony Playstation 3 (PS3) Console
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Posted on Oct 28, 2009
SOURCE:
Norcent model LT-2725 TV to ps3?
Check the video out settings of PS3.
Jul 27, 2012 | Televison & Video
I recently started downloading the black ops map pack, anyway while one was being downloaded my ps3 froze. It wouldn't turn off so i had to pull the cord out from the back. When I plugged it back in and...
This is a power supply issue. To stop further damage done to your PS3 console unplug it and take it to Tech Support immedeatly, ohterwise you'll irreversible damage to the console will happen.
Mar 06, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turns on but is not showing anything on my tv screen
If you are using the red white yellow cords then wiggle the yesllo cord thats the picture cord were it comes though and if that dont work make sure all the cords and in tite
May 29, 2010 | Sony Playstation 3 (PS3) Console
Sound works but there is no picture. The cords are
I had this problem myself. What I found was somehow the output resolution on the PS3 was changed to 480. If you change that back to 1080 it should work.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
No sound on tv or from the actual ps3 unit, no picture.
be sure all cords are plugged in correctly and that the tv itself works if nothing helps and its not any of the cords you may need to get it looked at.
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
Ps3
hook up usb for controler into ps3 then controller then hit ps button also use cords ps3 came with first with back power on but on stand by hold power button down for 10sec this should connect the controler to system as well as give you picture if it dosent check your tv with another device such as dvd player make sure the hook ups work
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
PS3 picture ans sound
make shur the cords arnt lose
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
PS3 Powers but doesn't show on screen?
try holding down the power button when you switch it on, for 4 seconds it runs the optimal settings screen and selects the best option for the leads fitted. hope this helps
Jan 19, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
85 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
