Question about Canon PowerShot A620 Digital Camera
No memory card on display
When I turn on my camera with a memory card inserted it displays no memory card. I have tried different cards and the same happens. I have tried to insert even a new card and reformat it in the camera but it will not let me choose the format function under the tools file. Can not take pictures and record to the disc.
  • 619 Answers
Hi , try to connect computer via usb scan with anti virus.
Posted on Jan 29, 2008
It displays an hourglass with a black screen when you turn it on
  • turn off remove and re insert the batteries first
  • remove the memory card
  • turn on the unit . if the hour glass does not appear try inserting a different memory card .
  • if this works your camera may have trouble reading the old card
Aug 23, 2014 | Nikon D5100 Digital Camera with 1855mm...
I have not used my Fuji Finepix 6800Zoom for many months so I charged it up and now when I turn it on 'ERR CARD' is displayed in the round screen. If I press Menu and then Back !card not...
May be you inserted a memory card formatted with your PC. Format the memory card using the Format function in the camera menu. Format function can be found in the setup menu of the camera.
If this does not work, try replacing the memory card.
Sep 02, 2011 | Fuji FinePix 6800 Zoom Digital Camera
Printer will not recognise camera memory card hp p315 photo printer
Was your Lexmark P315 printer able to detect this particular memory card before? Try to re-insert the card - it could be due to a slight communication problem. Have you tried inserting a different known working compatible memory card into the printer's card slot? This could be due to faulty memory card.
Also, please refer to Memory Cards Supported by the Lexmark P315 Photo Jetprinter.
Jul 26, 2011 | Lexmark P315 Photo Printer with 2.5" LCD...
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
My camera will not accept the memory card
Hello, one thing you might want to try is to format the memory card. To do this:
-Insert the card into your computer in the correct slot
-Wait until the computer displays found new hardware/device is ready to use
-Open my computer and look for the card(usually given a drive letter of H,I,J...) On most machines, it will be under a category heading of devices with removable storage
-Right click and select format
-Normally the default settings will work fine
-Select ok/format/continue
Hope this helps
May 01, 2009 | Kodak ZD710 Digital Camera
Canon powershot A70 digital camera
The memory card may be failing. Recommend trying a different memory card to verify. Do you still have the original low value card that came with the camera? If so, try that one to see if you still have the problem. If that one checks fine, then you know it's time for a new card.
Feb 14, 2008 | Canon PowerShot A70 Digital Camera
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Canon PowerShot A620 Digital Camera Logo
77 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
