First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working. You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Philips 37PF7320A 37 in.
Philips 37PF7320A 37 in. HDTV-Ready LCD Television
I reset my menu screen popping up in my phillip LCD unplug and them replug but still is popping up....
(More)
I reset my menu screen popping up in my phillip LCD unplug and them replug but still is popping up. What it may happen
I have a 37 inch philips LCD (approx 3 years old). Was working fine till about an hour ago. Now when...
(More)
I have a 37 inch philips LCD (approx 3 years old). Was working fine till about an hour ago. Now when I turn it on, the green light comes on for a fraction of a second (normally that's the light that stays green indicating that the TV on) but now immediately the green light goes off and a red light next to that green light starts blinking on the front panel and the TV doesn't turn on (i.e. remains black screen). All cables are connected and fine. It doesn't even take any input from the remote (ie even the system menus etc don't show - the screen is completely black). Also - the red light is blinking in a set pattern (four short blinks and then a long blink, and the pattern repeats). Any help would be highly appreciated.
tv gone back to factory settings.was working fine before and now when i try to follow instructions...
(More)
tv gone back to factory settings.was working fine before and now when i try to follow instructions to set up a message appears saying 0 digital services found and 0 analogue channels found.it then says check my antenna but i have it running through sky tv
My audio for my first input wont work. the picture is fine but there is no sound. what do i do?...
(More)
My audio for my first input wont work. the picture is fine but there is no sound. what do i do? Audio and picture both work for the second input, but when i put the cords in the correct spots in the first input, picture works, but there is no sound.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
