you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then remove the usb cable of the printer.
5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
NOTE: IF YOU HAVE ANOTHER PRINTER INSTALLED ON THE COMPUTER, DON'T PERFORM THESE STEPS, JUST RESTART THE COMPUTER.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
making grinding noises, paper catches, and will not continue printing process, also it doesn't work...
(More)
making grinding noises, paper catches, and will not continue printing process, also it doesn't work at all now I talked with the techician in India and after an hour, the problem was not solved.
I have had 926 printer for over 2 years and it has never worked correctly. It will print one page...
(More)
I have had 926 printer for over 2 years and it has never worked correctly. It will print one page and then stop. Next print just sits in que, and on and on. Have called Dell support and last time was on phone for over 4 hours with no satisfaction. Windows help said problem was something was in que and blocking prints? Any ideas?
The printer option on the printer is no longer available. Copy, fax,scan and maintenance is all that...
(More)
The printer option on the printer is no longer available. Copy, fax,scan and maintenance is all that shows up.
