Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Gas Oven
Today the power went off a couple of times and the oven was on. Each time the power went off the oven also went off. Please note that the oven is Gas but with an electric pilot. The Broil part turns on but it takes the power down. It takes short circuits and turns the power off to the whole house. The other part of the oven does not even turn on now. If you could please offer a solution what would be great.
    President:
  • 1,314 Answers
Honey the oven cant do that a gas oven is just 110 volts your house is on a 200amp breaker the oven breaker wold trip long before the whole house you better call an electricin and talk to him fast
Posted on Dec 30, 2007
After a short power outage, my Maytag Gemini Gas Range upper oven came back on (it was on at the time the power outage happened) and I cannot shut it off from the panel. I have tried to reset the oven to...
Hello, Thank You for using FixYa. I will be helping you today.After looking at the wiring diagram for this unit it looks like the only thing that can be happening is the relay on the control/clock is fused closed thus energizing the heating element. Bad thing is this part is about $360.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MER6769 Gemini Electric Kitchen...
My Maytag gas oven is taking a long time to preheat (45min)
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 15, 2011 | Maytag CWG3100A Gas Single Oven
Maytag propane gas oven Model# CRG7500AAL Serial# 15001534HU Problem is that the oven was taking a long time to ignite, this went on for a couple months, and now it will not ignite. Stove top burners...
This sounds like the igniter failed again. The only way to know for sure is to check the amp draw. Some cheap after market parts don't last as long as OEM. Here is a link that will walk you thru this http://appliancehelponline.com/gasoventroubleshootvideo.html
Aug 06, 2010 | Maytag Ovens
Maytag gas oven lock does not release
Unplugging it for a few minutes may reset it.
Sep 28, 2017 | Maytag MEW5530D Electric Single Oven
Oven heats very slowly
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Maytag gas oven takes long time to heat, sometimes not at all
sounds like a bad oven ignitor, part number 12400035 comes with all instructions on how to install
Dec 06, 2008 | Maytag CWG3100A Gas Single Oven
Oven Won't light anymore
when your oven was working did it "click" to start? or do you have a glow bar style ignitor. if yo u have a glow bar ignitor chances are thats the issue. if your oven would click to light then there might be a few issues on that but just like you top burners you should be able to light the oven with a long match and or barbecue lighter
Nov 11, 2008 | Magic Chef 31000 Gas Kitchen Range
Need to unlock Sabbath mode from Maytag MGR4452BDW
I have a Crosley gas oven and I had the same problem. According to my manuel it will shut off automatically after 72 hours OR Press the CLOCK pad for 5 seconds - no beep will sound. The Sab will flash and then the time will be displayed.
I hope this helps.
Oct 05, 2008 | Maytag Kitchen Ranges
F3 error code
f3 is the code to replace your oven sensor most you replace by pulling the back panel and removing the scerws
Feb 17, 2008 | Maytag MGR5750 Gas Kitchen Range
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Maytag Neptune MAH5500B Front Load Washer Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
