HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If the computer is running (Windows XP) and the HP6500 wireless is turned the computer locks up. Also if theprinter is on prior to booting the computer the window task manager eventually shows that 100% of CPU time is being used
Mitesh Kr Anand
Level 3:
  • HP Master 497 Answers
  • Posted on Oct 20, 2009
Mitesh Kr Anand
HP Master
Level 3:
Answers
497
Questions
0
Helped
184109
Points
1465
Some application like Anti-Virus software or Firewall is blocking the Printer to connect it to the Computer.
1. Try disabling the Anti-Virus software or Firewall in the Computer and check. Or add the Printer as exception in the Anti-Virus software or Firewall.
2. Try uninstalling and reinstalling the printer driver and check.
3. Power reset the Printer (turn it OFF, remove the power cable for one minute and then turn it ON) and check.
Good Luck!!!!
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Cannot access the internet . cannot enable ethernet connection or wireless lan device b ecause dont know the prior admin password
Go to the link below and download Ophcrack and burn the iso to a cd. Boot from the CD and let it do it's magic. You'll have the password shorthly:
http://ophcrack.sourceforge.net/download.php
5helpful
2answers
My HP6500 wireless all-in-one says its offline & my computer won't recognize it. I unplugged it then restarted it--didn't help. What does it mean to be offline? How can I get it online?
Press Start Devices and printers Find the printer you wish to bring online If you are using windows xp- double click on the printer If you are using Windows 7 or vista- right click on the printer and select "see what's printing" Hit "printer" in the menu bar Toggle the "use printer offline selection"
2answers
My Hp Photosmart C5820 all in one printer is connected to my HP Pavilion dv6000 laptop (Windows XP). How do I share this printer wirelessly with my new Dell laptop (Windows 7)?
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer. You need to install theprinter driver on the computer and configure it as a Shared printer. The other computers on thenetwork need to add this printer to their computer. Follow these steps toset-up a shared network printer :- 1. Connect the printer tothe computer and install the printer driver. 2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK 3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.
Follow these steps toconfigure the computers on your network :- 1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next. 2. Select Browser for aprinter - Next 3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next 4. Select Yes for - Usethis printer as the default printer - Next - Finish 5. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation. b>
When I boot my computer the monitor flashes the Windows XP logo then goes dark and the computer shuts down and then restarts itself and start the process all over again and again
Try starting it in safe mode, F8 during the boot process, this loads a windows shell, once active, run a system restore.
(Programmes - Accessories - System tools - System restore)
Choose a date prior to your problems.
Sierra Wireless Compass 597 after install Vista will not reboot.
your vist disc can be booted ontop of Xp if your tower is running when your screen goes blank do you have a grafics card installed you may need to disable this back to default in bios setup
2helpful
2answers
Well you please tell me default IP address of LINKSYS Wireless-G Print Server
Installation of WPS54G Print Server
Using standard TCP/IP Procedure (Windows XP/2000)
  1. Make sure your printer already has its drivers installed on all PC's prior to attempting to install this print server.
  2. Be sure also that your printer can print when it is connected directly to your computer.
  3. Click on Start go to Printers and Faxes.
  4. Right click your printer and go to Properties.
  5. Click on the Ports Tab on the top.
  6. Click Add Port. Select Create a new port: and select the Type of port: Standard TCP/IP Port, click Next.
  7. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  8. Inthe field for Printer Name or IP Address: enter the IP address of thePrint Server and click Next. (You can get the IP address of your printserver by pressing the reset button on your device for 3 seconds thenit will print out it's status).
  9. Select Custom, click Settings.
  10. Under Protocol select LPR, and for Queue Name: type L1. Click Ok, then Next, and Finish.
Youshould be able to print on the device afterwards. You can refer to yourRouter's Wireless Settings and match them on the WPS54G so that theywould be able to communicate wirelessly.
2answers
Toshiba Laptop A55-S306 shuts down with error messages
It sounds to me like a virus. Boot up from a recover cd or windows cd and reinstall freashly.
If you don't have a recovery cd, contact Toshiba for one. They go around for $40 to $50. If you can't get one, buy Windows Vista and boot up from that and reinstall.
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
k24674
Grand Canyon Tech
Grand Canyon Tech
