DVD stuck inside, player won't turn on, standby light does NOT flash
So I have had this player for a couple years and recently it started flashing the standby light, and I read about changing the c316 capacitor out and I did, and it worked great for awhile after that. But all of a sudden it's not working again, and the dvd player won't even eject. The standby light will show the machine's plugged in, and then when I press any button, it goes off for maybe 5 seconds and then just comes back on. I don't even hear any noise going on inside the machine. The capacitor is soldered in and everything, made sure the negative post was on the dashed side, and I know that all of the capacitors look fine, not bulged. What else can it be?
Re: DVD stuck inside, player won't turn on, standby light...
Test the capacitor with a meter to make sure it has the value stated on it. the work on this unit is quickly exceeding its present value, most likely. consider upgrading to a higher resolution unit if the fix is more expensive in parts and time than a new unit costs. good luck mark
hi,
To make your BD player you need One for all universal remote control
Full procedure for a oneforall remote is as follows:
1. Press DVD 2. Hold the magic button until the DVD button flashes twice. 3. Press 0533
4. Hold the magic button until it flashes twice. 5. Press 994 6. Press Magic Key (don't hold) 7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros) 8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice. 10. Press 994 11. Press Magic Key (don't hold) 12. Press 00255 13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice. 15. Press 994 16. Press Magic Key (don't hold) 17. Press 00095 18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice. 20. Press 994 21. Press Magic Key (don't hold) 22. Press 00221 23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice. 25. Press 994 26. Press Magic Key (don't hold) 27. Press 00079 28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDV-E370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it. 2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light) 3. Put the player back into standby with the Sony remote. 4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely. 5. Next time you turn on the player it will be region free for DVD playback. ok
hi, to make ur player region free for dvd u should have a Oneforall universal remote wich acept 4 digit code Firs of all u have to program the remote for the purpose. procedure is as follows
1. Press DVD
3. Press 0533
5. Press 994
10. Press 994
12. Press 00255
15. Press 994
17. Press 00095
20. Press 994
22. Press 00221
25. Press 994
The remote is now programmed and ready to use, to make the BDP-S360 region free:
ok
hi, do the following with one for all universal remote. to make ur player region free u have to purchase a one for all universal remote.
Programming a BDP-S550 for Region free DVD playback (It does NOT change Blu-Ray BD region playback)
NOTE:This does NOT work on USA Region 1/A players. They do not contain
the hardware that is included other Sony players sold in other
countries.
Full procedure for a oneforall remote:
1. Press DVD
2. Hold the magic/set button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic/set button until it flashes twice.
5. Press 994
6. Press Magic/Set Key (don't hold)
9. Hold the magic/set button until it flashes twice.
10. Press 994
11. Press Magic/Set Key (don't hold)
12. Press 00255
14. Hold the magic/set button until it flashes twice.
15. Press 994
16. Press Magic/Set Key (don't hold)
17. Press 00095
19. Hold the magic/set button until it flashes twice.
20. Press 994
21. Press Magic/Set Key (don't hold)
22. Press 00221
24. Hold the magic/set button until it flashes twice.
25. Press 994
26. Press Magic/Set Key (don't hold)
27. Press 00079
The remote is now programmed and ready to use, to make the BDP-S550 region free:
of standby, make sure there isn't a disc in it. It should read "HOME"
on the front panel.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The blue 24p light will start flashing on the front panel
4. Next time you turn on the player it will be region free for DVD playback
ok
hi, u can make your dvd for region free DVD play back. but for that you have to purchase an universal remote (ONE FOR ALL URC-7950). through this remote only you can make player DVD region free. first of all u have to set( program) the remote for the same purpose.
Full procedure for the OneForAllURC-7950 remote is as follows:(preparing remote)
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994 6. Press Magic key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
12. Press 00255
14. Hold the magic button until the red led flashes twice.
15. Press 994
19. Hold the magic button until the red led flashes twice.
20. Press 994
22. Press 00221
24. Hold the magic button until the red led flashes twice.
25. Press 994
The remote is now programmed and ready to use, to make the BDP-S370 region free
2. Press 1, 2, 3, 4, 5 on the OneForAllURC-7950 remote. The power light will start flashing. (blue middle light)
4. Next time you turn on the player it will be region free for DVD playback.
OK
one for all rc 7652 works for this as do many others. 1. Press DVD
3. Press 000533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
7. Press 001891 (this sets key 1 – the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 002552 (this sets key 2 – the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 000953 (this sets key 3 – the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 002214 (this sets key 4 – the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 000795 (this sets key 5 – the DVD button flashes twice) Done - the remote is now programmed and ready to use
Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
2. Make sure there isn't a disc in the machine.
3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing)
4. Put the player back into standby with the Sony remote
5. That’s it, the next time you turn on the player it will be region free for DVD playback
I personally dropped the 00 that are marked red and it worked for me but it depends on model of one for all remote.
Yes there is a hack to make the DVD region free, as far as I know there is not one for the Blu-Ray as yet.
You will need your original remote and a 7040 OneforAll remote to enable region free playback of DVD’s on the Sony BDP-S350.
Programming the 7040 OneforAll remote.
1. Press DVD
3. Press 0533
5. Press 994
7. Press 1891 (this sets key 1 – the DVD button flashes twice)
9. Press 994
11. Press 2552 (this sets key 2 – the DVD button flashes twice)
13. Press 994
15. Press 0953 (this sets key 3 – the DVD button flashes twice)
17. Press 994
19. Press 2214 (this sets key 4 – the DVD button flashes twice)
21. Press 994
23. Press 0795 (this sets key 5 – the DVD button flashes twice)
5. That’s it, the next time you turn on the player it will be region free for DVD playback If the blue 24p light doesn’t flash then it hasn’t worked, try a new set of batteries and start a fresh
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs?
no
as you say that sound is ok that means your power supply &high voltage section is ok.
please check chroma ic luminance section or system control section stand by ckt
ihanks
i don't have a meter. i got the one recommended, the 1000mu F35V...
