Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out Your control is set to use a 12-hour clock. If you would prefer to have a 24-hour military time clock or black out the clock display, follow the steps below.
Press the BAKE and BROIL HI/LO pads (on models, use the upper oven controls) at the same time for 3 seconds, until the display shows SF.
Press the CLOCK pad once. The display will show 12 hr. If this is the choice you want, press the START pad.
Press the CLOCK pad again to change to the 24-hour military time clock. The display will show 24 hr. If this is the choice you want, press the START pad.
Press the CLOCK pad again to black out the clock display. The display will show OFF. If this is the choice you want, press the START pad. NOTE: If the clock is in the black-out mode, you will not be able to use the Delay Start function.
Some clocks are only 12 hour and some 24 hour and others have both options and this you will find on the inside of the clock on the movement. If there is no option on the movement then you cannot change it.
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
