Question about RCA RT2250 System
Rca 2250 I have had my receiver for a while and it has always worked well but now me right main speaker is not working but all others are. I have hooked up several different speakers to it and none of them work out of the main right jack. This is totally ruining my optical and coaxial digital sound and it is very frustrating. Can it be fixed?
  • 99 Answers
Sounds like your right side output is shot. And yes it can be fixed, but the cost factor would be higher than what you paid for the set itself. First see if your inputs are working correctly, this also could be your problem. Check all your connections.
Posted on Feb 09, 2008
I added a turntable to a onkyo sir TX 576 using a preamp to power it lean the preamp into VCR DVD in and in only getting. Music out of main speaker right and none out of main speaker left?
Hi Dave, please make sure that the RCA plugs are all the way in. Try flipping them, red to white and white to red. See if the audio moves to the other speaker. If it does the receiver and speakers are ok. Try a different analog input. Thank you, Onkyo USA
Dec 04, 2016 | Onkyo Audio Players & Recorders
Only one speaker working
pls. identify w/c channel is working then try switching the speakers, check your rca cords from your source player, try to switch them. th
May 05, 2013 | Integra DTR-9.1 7.1 Channels Receiver
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
Bose 901 Hook up help !
The use of 901's in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor.
That is because if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. However, you can still draw the Front Left and Right signals out of any Pre-Out (with a Y-cable set, looping the Pre Out directly back to the Main In) or Tape Out jacks (remembering to NEVER activate that monitor on the receiver), go into the Active EQ's Amplifier Connections; then Out of the EQ's Amplifier Connection to a separate amp and attach the 901's to that amp. This way you won't introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed. This is how mine is wired.
Come to think of it, you could still have conventional Front L&R speakers on the AV Receiver, but why? Maybe one would prefer the 901's for music and some other speakers for surround. Level matching with the 901's to conventional front speakers would only be possible if the separate amp has its own volume, but it would work. Maybe I'll try it someday. None of my current amps has a volume control.
Oct 22, 2009 | Bose 901 VI Main / Stereo Speaker
Hi, I just purchased a used set of 901s with the original active equalizer. they are both series VI and were bought together. Unfortunately, the man misplaced the installation instructions for the...
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
Jul 15, 2009 | Bose 901 VI Main / Stereo Speaker
Zone 2 speakers only work with the tuner - no sound comes out when switched to DVD, Cable/SAT, ect. All of my other devices (DVD player, Satellite Receiver, ect.) run through the receiver. How do I get...
hi,
zone 2 will only work with analog sources so if your dvd, cable and other devices are connected via HDMI, that alone won't work. What you need to do is hook up RCA (red and white) cables from the dvd player to dvd in of the receiver and same thing for your satellite box (and other sources.) no need to change any setting on the receiver. This way, the HDMI will take care of your main room speakers and the RCA will feed your zone 2 speakers.
Hope this helps.
Jun 10, 2009 | Onkyo TX-SR605 Receiver
The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Apr 06, 2009 | Yamaha RX-V663 Receiver
Dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Enjy!
Feb 27, 2009 | Bose 151SE Main / Stereo Speaker
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
RCA RT2250 System Logo
161 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
