Home | Sony | FD Trinitron WEGA KV-36FS120 36" TV | Picture on tv keeps goi...
Sony FD Trinitron WEGA KV-36FS120 36" TV
Problem for Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture on tv keeps going out and coming on
By nickjohnson2 on Oct 20, 2009
picture on tv keeps going out and coming on
Best Solution
posted on Oct 26, 2009
Helpful)
mickt6685
Rank: Apprentice
Rating: 88%, 2 votes
hi
problem could be a bad cable connexion or a
intermittent tuner but first you have to eliminate the cable connexion probability
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 20, 2009
Somewhat Helpful)
shaiparikh
Rank: Wiz  Televisions & Videos  Expert
Rating: 78%, 20 votes
pls check your tv. cabel input pin or atached canaction is not proper.
1. cabel pin Out from the tv set and check pin canaction is proper.
2. if use setup box . check RCA pin [A/V] or cabel .reset the canaction.
3. all cheenal set with Auto Cheenal Serch properly.
Was this helpful?
Yes
No
Solution #3
posted on Nov 06, 2009
Not Rated)
xxx-tvrepair
Rank: Guide  Televisions & Videos  Expert
Rating: 88%, 4 votes
If the previous posts didn't fix youru problem, and I doubt they did, then you most likely have a weak CRT and the video is being muted. you can sometimes tell if that's the problem by turning up the screen voltage slightly to see if the picture comes back on. If it does, then the CRT is weak. This is a very common issue with Sony CRT TVs, and can sometimes be rejuvenated by a good shop for fairly cheap.
Was this helpful?
Yes
No
Solution #4
posted on Nov 05, 2009
Not Rated)
Chu3505
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 85%, 388 votes
Best solution to solved this prob.U know how to solders?Take the tv aparts hit the video board.The board connected to the CRT tube long neck.Hit the board with a back of handle of a screw driver,where the video fades flashes resolder it well solved this prob.Solder the pins sockets holes connections to the CRT neck too.
Was this helpful?
Yes
No
Popular Solutions for Sony FD Trinitron WEGA
Questions and Unsolved Problems for Sony FD Trinitron WEGA
Do you recommend Sony FD Trinitron WEGA KV-36FS120 36" TV?
Answer
Answer
kv-28hx15u TV won't turn on, just clicks?? then the green led flashesgreen and red
Answer
T.V on off switch needs to be cycled several times for T.V to turn on then it works fine but it is... (More)
Answer
on off button flashes red and green no picture on screen what can I do have pulled plugs and waited... (More)
Answer
there are bright color lines across the screen, for example there is a red line, then below that a... (More)
Answer
TV does not turn on, LED Blinks 5 times, breaks, then 3 more times
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony FD Trinitron WEGA...:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
