Question about Sanyo DS27800 27" TV
Picture to wide for tv screen
How can i bring in the sides of the picture? there are no adjustments on the back for vertical or horizontal. when watching some stations i really notice this alot. when playing games it seems that the pic needs to be centered and the sides readjusted. if i pull off the back will there be anything inside to adjust? I havent taken the cover off yet.
i haven't had any problems at all with this tv and the pic is as sharp as it was when new.
  • 149 Answers
Hi there, try to adjust it in the remote control, else you have to open it for check up., some unit have adjustment inside the unit, you may have a very high voltage output, check the power supply section. do some test. ty
Posted on Dec 29, 2007
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Picture is too wide to fit screen can not see complete picture
hi there, i don't know your TV brand but this could be of help anyway. there is an adjustment for horizontal and vertical width. you can manually adjust the setting until it fits the picture on the screen. for standard TV it has trimmer in the CRT board. If in your case you have a soft adjustment in the remote control try to adjust it. Learn how the menu works just look for the picture adjustment.
Good luck, please rate and vote.
Mar 20, 2011 | Televison & Video
HI, I was wondering if there is way to adjust the horizontal position on the screen of Sony KP-57WV600. By adjusting I mean a way to shrink the displayed picture horizontally or vertically.To give you an...
There is button "Wide Mode" on tv remote, press it repeatedly to select desired zoom mode to view best fit picture in screen.
Click Sony Support link to download user manual free copy and check page-48 for details.
Jan 06, 2011 | Sony Televison & Video
If the picture is too wide, both in vertical and horizontal direction your TV needs power supply adjustments. It is now running at overvoltage, and this condition may poise to another problems soon. Get it repaired soon. Its internal regulated voltage needs to be adjusted. You cannot do it by yourself. Get it repaired by the help of a technician. Don't switch on the TV till its fault have got rectified.
Oct 18, 2010 | RCA F36668 36" TV
40 in LCD Proscan TV, Horizontal pic too wide, adj?
just look at the owners manual of how to adjust the picture
Jul 23, 2010 | Proscan 42LA45H 42 in. LCD TV
Viewing mode will only go from zoom to wide!!!! please help
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Adjust manual picture on TV
Sounds like you may have caps going bad . Adjusting may tend to only stretch the the picture too much . Also when you say horizontal are you saying the top and bottom are closing in ? If yes then your problem is in the vertical section . If side to side then check the horizontal section . Good luck
Mar 01, 2008 | Televison & Video
Picture too wide for screen
your problem is called blooming as you might be aware of very high voltage in tv. you can check 1 high output voltage fron power supply. 2 if it is ok then the problem is in horizontal can check hor. section at last flyback transformer. hope this will help.
Sep 25, 2007 | GE 31GT659 31" TV
Adjusting the TV horizontally
There is not a horizontal center on this TV set. This is a fault with the horizontal sweep correction circuit I'm afraid. This circuit is a high voltage circuit and should onlt be serviced by a trained tech. Good Luck
Jun 28, 2007 | Sharp 55R-WP4H 55" Rear Projection...
Sanyo DS27800 27" TV Logo
66 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
