try to resolder the heated area and then check...if the problem exits..then check out your vertical and horizontal deflection coil......could be the problem...most cases, it needs re servicing
TV works fine but makes a "popping" noise periodically, particularly after it's been on...
(More)
TV works fine but makes a "popping" noise periodically, particularly after it's been on for a while. I just want to know whether this is indicative of a problem, or just something these TV's do.
I have a phillips 50'' plazma tv about a yr old, in the bottom lefthand coner there is a little blue...
(More)
I have a phillips 50'' plazma tv about a yr old, in the bottom lefthand coner there is a little blue light when the tv is on, now, when I go to turn the tv on, it doesn't go on and that light blinks 6 times with a different color, what's up?
My tv won't keep my adjustments and returns to the 'soft' picture setting after I power it off. How...
(More)
My tv won't keep my adjustments and returns to the 'soft' picture setting after I power it off. How can I get it to use my personal settings when I turn it back on?
problem when turn on the tv have difficulty to turn tv on just the red light blinks...i turn it off...
(More)
problem when turn on the tv have difficulty to turn tv on just the red light blinks...i turn it off and on about 10to 15times and tv came on what's problem??
i turn tv on the green light comes on and a few seconds later tv is off and red light is blinking 3...
(More)
i turn tv on the green light comes on and a few seconds later tv is off and red light is blinking 3 times, then 6 times. i unplug then plug, green light comes up then stsrt blinking red, tv doesn't start. the red light is blinking in a sequence. how do I tell what the sequence means?
