Samsung M320 Cell Phone Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot send files to my samsung m320 from macbook through bluetooth. the two devices do pair but, at the time of connection, the connect word on the bottom left of the phone screen (as according to phone manual instruction for bluetooth connection) does not even appear.
Anonymous
Level 2:
New Friend:
  • Expert 121 Answers
  • Posted on Oct 26, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
121
Questions
0
Helped
22649
Points
197
You may contact the service provider.......
2answers
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 • Cell Phones
I just got the new Kin Onem. I have a macbook and I'm trying to set up the bluetooth connection from my phone to my computer in order to transfer files such as pictures. My laptop is recognizing that...
I believe the kin's bluetooth is only for pairing with headsets and possibly sending a file. I doubt it is possible to actually browse the phones file system from the macbook. Try looking for an option on the phone to send the file via bluetooth instead of trying to browse the phone from the macbook.
Hi, My Samsung mobile is GT-C3303. I have problems in connecting to the bluetooth device on my laptop machine to transfer the music files. I have tried both 0000 and 9999 and 1234 but nothing is helping...
you have to pair your samsung phone to your laptop first before you can start sending and receiving files through bluetooth.
an option is, turn the bluetooth on your laptop on, then the bluetooth of your mobile phone on. on your phone, search for devices, then once you see the name of the bluetooth device of your laptop, tap it then choose connect or pair, you will be asked for a passkey (you can input anything try 0) or in some devices wait until a pop screen appears which will contain the passkey usually 5 to 6 digits. then click ok
another option is (i tried this using my samsung corby wifi and a samsung n150 laptop and it works just fine) make sure that the bluetooth on your laptop and phorne is turned on. on your laptop click on the bluetooth icon or click the file you want to send, then right click, then choose send to bluetooth, your laptop will then search for available devices, just choose your mobile phone then automatically there is a popscreen which has a passkey, then click ok. on your phone you will be asked to allow to connect thru the laptop, just click ok, then make sure that the passkey matches between your phone and laptop. (usually it is automatic, you just need to click ok) you should be able to send and receive files thru bluetooth on your phone and laptop
1helpful
2answers
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
How to connect samsung tocco mobile to another samsung tocco mobile using bluetooth?
Turn on the Bluetooth wireless feature.
To turn on the Bluetooth follow the below steps,
1. In Menu mode, select Applications > Bluetooth.
2.. Select the circle in the center to turn on the Bluetooth wireless feature.
3.. To allow other devices to locate your phone, select Settings > On under My phone’s visibility > Save.
To connect other device to your mobile
1. In Menu mode, select Applications Bluetooth Search.
2. Select and drag a device icon into the centre.
3. Enter a PIN for the Bluetooth wireless feature or the other device’s Bluetooth PIN, if it has one, and select OK.
When the owner of the other device enters the same PIN or accepts the connection, pairing is complete.
After connecting you can start sending the files from one mobile to another mobile.
To send files follow the below steps.
1. Select the file or item from one of your phone’s applications that you want to send.
2. Select Send via or Send URL via Bluetooth, or select More Send via Bluetooth
Thank You
1helpful
I can't connect my Samsung Jet with my PC via Bluetooth. What am I doing wrong?
to connect your samsung phone to a pc via bluetooth you need to follow the steps.
1. install your samsung pc suite NPS,
2. open your phone bluetooth.
>> go to menu, select bluetooth, select settings under bluetooth, make your phone bluetooth's visible,
3. go to your computer, open your bluetooth, right click the bluetooth icon on the system tray, they are grouped and can be located near the clock.
4. select settings for your computer's bluetooth, make it discoverable, check the discover services.
5. under the computer's bluetooth panel, you can see there add device, click add device.
6. once the computer search for your phone, pair them with passcode like 1234, or 0-9 digits, it's up to you to assign the passcode but make sure they will be having the same passcode. ( both computer and phone).
once paired you can see them there in your phone's bluetooth panel, your computer and your phone together.
>>to check if successful connection was achieved, select a file from your computer, right click and send to your phone.
>>do the same thing for your computer, select a file from the phone and send it to your computer, but you need to confirm that your computer will be receiving a file from a paired bluetooth, by clicking the balloon
message at downright corner of your computer where your bluetooth is located.
regards...
Samsung M320 wont pair with ilove i316 bluetooth
Try removing the battery and re-pairing after reinstalling the battery and turning on the Samsung M320.
I've written a short article on other bluetooth troubleshooting here: http://yourmonstersofmobile.com/how_to_for_cell_phones/pairing_your_bluetooth.html
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
