Question about Ovens
Whirlpool Gold double electric oven Model GBD277PDB1 lights
Approximately 3 years ago we had to have the touchpad panel/computer board replaced for the oven referenced above. Now the lights in both ovens won't shut off, and the tech says the computer board has to be replaced (again), at a cost (parts and labor) of $450. Does this sound like the proper solution? Is it common for this model's computer board to have to be replaced every few years? The oven is approximately 8 years old.
Thank you for any help/suggestions you can provide.
  • 1,314 Answers
In answer to your question no not that your tech is bad his stuff is honest most of the costs are parts what i would is do contact whirlpool cust assistance and talk to them dont confuse cust assistace also known as custmer relations with with customer service they are not the same cust relations could give you the parts and then you can pay labor if your going to keep the oven see about a service contract on it ge or whirlpool both have good ones whirlpool cares about there cust so be nice when you talk to them like my mom had whirlpool ive allways had whirlpool but i just dont understand whats going on with this oven etc good luck
Posted on Dec 29, 2007
How to remove side panels on a whirlpool Gold double oven, in order to remove control panel. I would like to reconnect the control panel, it may reset the panel to work again
Hello Ms Jackson,
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty.
I've also attached a link on how to remove your Whirlpool oven control board How to Remove Whirlpool Oven Control Board
Feb 10, 2017 | Whirlpool Ovens
Have a Whirlpool Gold dbl. oven. Last Fri. night oven started beeping and display the E0F2 code. Turned off brk'r till next a.m., turned on only to have in a rolling sequence going from 350 upper oven...
Good Evening!
Do you have the full model number of your appliance? Do all of the buttons beep when pressed? If not, unfortunately, the touchpad on your unit may have failed again. An E0-F2 is a stuck key error. The only way to fix this issue would be to replace your touchpad. Your more than welcome to send in your touchpad and control board for evaluation and testing. Contact us for more information We also have replacement touchpads for your oven if the original OEM part is discontinued.
Ledgestone Technologies Keypad and Ribbon Cable Installation
May 25, 2017 | Whirlpool GBD277PD Electric Double Oven
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Gold double oven - started beeping then all lights on the control panel went out. Reset the circuit breaker which makes the oven beep but still have no lights. Oven will not operate.
I was just looking over a manual for a late model double oven. Their is a thermal limit going into the controls that will open if the temp rises enough to harm the controls. They look like this one.2605a73.jpg That kills all power to the control and you will see nothing on the display.
This manual will give an idea where to look:
Late model double oven
Sep 27, 2010 | Whirlpool GBD307PDS Electric Double Oven
The display on the control panel is not showing on my double oven .
u may have a bad connection between that touchpad to the control board. some had 5yr parts warrantys on the parts depending on when u purchased it it may apply.. if not you probably neeed to replace that touchpad which they want allot for average price probably 200-400 for just that touchpad i know its ridicoulous but prob better than buying a new walloven.....u may need service but this is probably whut they will tell you.. hope this helps
Feb 05, 2010 | Whirlpool RBD245PDS Electric Double Oven
Key board will not light up...Nothing....Oven light will come on......TTT
Whirlpool RBD305DQ15 Electric double wall oven, the control panel does not light up so you can't tell what you are doing. Do I need to replace the whole board or is there a fuse to replace?
Oct 05, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for:
appliance parts, help & more
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Error Code E1F2
looked up tech sheet for this model and it states E1F2 - keypad connection not detected.. check connection, press cancel if returns in 60 secs replace keypad.then lists to replace control.
Mar 01, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
169 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
