Check your high voltage ic(H-OUT TRANSISTOR) if it is damaged, then change it with same type.....resolder the main board..other options are, to check capacitors, fusable resistors near high voltage area...re-solder on vertical ic....if you are familar with electronics, or take to qualified service tech
