USB Hard Drive - Won't recognize
I have attempted to utilize a Kingbyte (?) external USB Hard drive to no avail. There was a floppy disc included with the set, but everything I've tried still results in an error message about the USB devise not be recognized. Recommendations?
Thanks.
I have Western digital 60G USB 2.0 HARD DRIVE .IT RECOGNIZES SOME COMPUTERS WHICH I HAVE VISTA AND WIN XP.i HAVE ANOTHER ONE GATEWAY WITH VISTA WON'T RECOGNIZE THIS SAME HARD DRIVE BUT ALL OTHER FLASH DRIVE WORKS ON SAME USB 2.0
I have one of those portable passport WD hard drives, i had the same issue. But when i tryed the pc rear usb ports it worked fine, you can also just look up drivers for your HD and install manually
Posted on Aug 24, 2009
  • 1,006 Answers
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
or
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Feb 17, 2008
NewerTechnology uDriveSmartDisk USB Floppy Drive (model FDUSB-M, Color Kit Edition, formerly VST)
Verbatim continues to offer support on select SmartDisk products:
CrossFire USB & FireWire Desktop Hard DrivesSOHO NAS Desktop Hard DrivesFireLite USB & FireWire Portable Hard DrivesFireLite XPress Portable Hard DrivePhotoBankUSB External Floppy DriveSelect models of CameraMate Card Readers
For online support click here:
http://www.verbatim.com/contact-login.cfm
or call technical support at 646-537-3411, Monday-Friday, 8 a.m. to 9 p.m. Eastern Time.
Verbatim Acquires SmartDisk External Hard
Disk Drive Business
Verbatim Acquires SmartDisk External Hard Disk Drive
TOKYO, (July 5, 2007) - Verbatim® Corporation and its parent company Mitsubishi Kagaku Media (MKM), announced today the purchase of substantially all of the assets of SmartDisk® Corporation\'s external hard drive (HD) and digital imaging business.
The acquisition, which includes physical assets, patents, trademarks, technology, engineering and marketing expertise, was effective on June 30, 2007.
Feb 12, 2013 | SmartDisk USB Floppy Drive Titanium...
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
I won a Seagate ST30000CB, Part # 9Y7865-560 Serial # 5QF3J7W7 and need get Seagate Disc Utility CD. How and where can i get same or how can I download ?
I'm not sure what Seagate Disk Utility is, do you mean SeaTools? That can be downloaded from the seagate website (also includes installation download). As for the disk Utility, what are you trying to do with it, or what do you need it for? If you give me some details I can suggest a program which might solve your problem. Also be sure to include your operating system name and version (IE Windows 3.1). Thanks!
Sep 12, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
Can't get my TEAC External Floppy Drive FD-05PUB to be recognised by my Mac Powerbook G4 running OS 10.5.8. Solutions?
Was it ever recognized?
Is it recognized on other computers?
Notebooks sometimes have poor power output on USB sockets; try all available USB sockets, and as a next step try a POWERED USB hub - ie a hub with it's own, separate power supply.
Aug 08, 2010 | Teac (FD05PUB/KIT/TI) External Floppy...
I just purchased a Diablotek 1.44MB External
USB floppy drive support may not enabled by default in the BIOS. Enter the BIOS setup utility and enable USB-FD support.
Mar 13, 2010 | Teac FD-05PUB External Floppy Drive
Cannot get drive to recognize in my computer- red light followed by flashing blue light
Is this a new hard drive, if so did you initialize it with the included software? new drives need to initialized when first powered up. Install the laptop and boot the computer using the included software, the disc will initialize and then you can reboot using your windows or restore disc to finish.
Aug 30, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
I have had to reinstall my operating system and drives but now the Seagate 500 GB external is not recognized. What now?
Are you using eSATA for the External or USB. If it is eSATA you may need to get the respective drivers for your motherboard for it.
Jan 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Secure HD Login Problem
in applications there is one called utilities in this is one called disc utilities see if the drive shows up ? if it does try repairing permissions and verifying the disc.
Aug 28, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
this problem depends on your OS, or if that is a really bad pendrive,
if you have windows 9x most of the times you must use that pendrive as a normal hard drive.. with this i mean you have to plug it in, and then start your pc, and to take it out you must turn off the pc..
if its a really bad pendrive, installing the drivers will help, but because those thingies are really lame, they will get busted really fast.
but you can be sure that your USB entrances in your PC are fine because they are recognizing something is in, so the problem is the Operating System, either being too old or lack of drivers.
by the way.. is it a KINGSTON? or a kingbyte?
Dec 18, 2007 | Computers & Internet
Computers & Internet Logo
2,538 people viewed this question
Alun Cox
David Payne
David Payne
