Related Tags:
This problem should be removed because:
Problem with HP Officejet 5610 All-In-One InkJet Printer
how can i install manual HP Officejet J4500 printer
Solutions (2)
Best Solution
You can install the printer software both either using the cd software that is included in the package or you can download the software www.hp.com/support. Make sure that you are installing the correct printer operating software. instead of doing a recommended installation choose advance install and uncheck the software that you think that is not needed by you. hp solution center is an important software. also the hp imaging device. but before you proceed in installing make sure that your anti-virus, firewall, spyware are turned off. There are times that the printer software function will not work because it is being blocked by the firewall, spyware and anti-virus. enjoy installing the printer.
if you do have a software cd put in the software ithout conecting the printer to the computer and do not turn onn the printer
go to my computr >> and open d: drive
now once the cd plays select install
after that it will ask you how would you like to install the printer (select USB or wireless )
click next
then will ask you to what can of installation do you ant to do ......... select recommended
after that it will ask you to connect the printer to the computer if it is a USB connection
turn on the computer and connect the usb cable to the computer
it will configure the printer and at the end it will ask you to print a test page ... click on yes and see whether it is printing .................... if yes the printer has been successfully installed in your computer and if no .................. let us jnow what exactly happens and do you get any error message .......................
I think it should work
wish you good luck
thank you .....................................
Suggested Solution (3)
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
perfect! ur better than HP themselves :)
thanks
This also worked for my black cartridge on my HP officejet 4500 wireless.
Thanks a bunch!
Source: HP J4500 color cartridge error
you can download the guides and manual at the following link
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3645100
Mark
Source: I want a hard copy of users guide for officejet j4500 all-in-one
try http://h10025.www1.hp.com/ewfrf/wc/setupCategory?lc=en&dlc=en&cc=us&lang=en&product=3645094
Or http://www.hp.com/#Support Selest "see support and troublshooting info"
Hope this helps
I want a hard copy of users guide for officejet...
Trying to obtain the users guide for HP officejet j4500 all- in- one printer ,scanner, copier, and fax
No operating manual with J4500
Do you provide an operating manual with your printer ? there was none for the new printer I bought. a Manual came with my Hp 5700 when I...
Instruction Manual for Officejet j4500
HP officejet J4500 It says the tri-color cartridge is malfunctioning.I've removed it and put it back in place. It is a relatively ne...
everytime i put in the disk for the officejet
everytime i put in the disk for the officejet j4500 it says my computer isn't compatable with this unit I run windows 7 it says to fix...
Add Your Solution
HP Officejet 5610 All-in-one Scanner - No reaction
I changed cartridges to two new original ones. I did everything i should in installing them. The printer starts to Align...
HP Office jet 5600 doesn't work (without the...
Upper the print head, there is a "rule" transparency It is out and now my printer doesn't...
my 5610 all in one wont print or scan red...
it has done this before after a few days it started working it woked for a while then stoped it worked for 1 day now it...
HP OFFICEJET 8500A PLUS WONT SCAN TO PC FILE
WON'T SCAN TO A FILE FOLDER ON MY PC
doesn't print correct borders
I have tried multiple custom settings and multiple combinations of print options and no matter what, it HP 5610 still...
See all HP Officejet 5610 All-In-One InkJet Printer Problems
Related Topics
Fix-O-Meter
829
829 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top HP Printer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
