Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Rca tube tv
New rca tube tv turns itself off every few seconds sleep timer is off
  • jerryrose Dec 29, 2007
    where is horizontal section?
    thanks so much for info. not a tech and now realize that i sould return tv.
  • 149 Answers
Hi there, there is a problem at the horrizontal section, some mostfet transistor is defective, do some test at the horrizontal section. ty
Posted on Dec 29, 2007
  • Redentor Rey Jr
    Redentor Rey Jr Dec 29, 2007
    hello, the landmark for horizontal section is the FBT. you have a mosfet transistor problem at the horizontal section, its a complicated situation if you are not a tech. hope i can help. ty
TV turns itself off?
I am sharing four cases in which your tv either turns itself off or appears to turn itself off.
TV appears to be off
  • You using your tv as a monitor or your pc is in sleeping mode.
  • Your cable or satellite Box is not outputting a signal.
TV turns iteself off
  • The sleep timer is set.
  • The off timer is set.
Your tv appears to be off:
If you are using the tv as a monitor If you are using tv as a monitor and the stand-by light only
blinks for a few seconds when you press the power button,your pc is in the sleeping mode. To take your pc out of sleep,press a key from your key board or move the mouse.Tv turns on.
If you are using TV with a cable or satellite Box
If you have a cable or satellite Box your Tv may appear be off because the cable or satellite Box is not outputting a signal.Press the guide or info button on the cable or satellite Box remote control.
if the screen displays info or guide data,the problem is caused by the Box,you must call your cable provider.
if screen does not display info data,change the source on your TV.
Nov 14, 2014 | Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
TV powers on screan comes and then powers off after a few seconds
Pls look on your remote control, select the "sleep mode" to off. Sleep mode might be on. Or adjust the time whrere what time you want it off automatically. Just simplt turn ot off the Sleep mode. Check timer of your Tv.
Jan 18, 2011 | RCA HD61W66 61" Projection HDTV
Hi my rca truflat 20 inch tv stays on for about 30 mins then displays an analog clock and turns off
Your sleep timer is on. Hit menu, and poke through that and find the sleep timer settings. Sleep timer is something that turns the TV off after an amount of time that your do not interact with it.
Sep 17, 2010 | RCA Televison & Video
RCA model 27F634T
on that one ive had the button board causing problem--remove board--spray wd40 on buttons--push buttons a few times--wipe off bwd--reinstall bwd
Sep 16, 2009 | RCA 27F634T TV
RCA 32V434T TV turns itself off and on by itself. Any suggestions on how to fix it?
When your tv turns on by it self you prob have the alarm set. For the tv to turn like a clock would go off when u need to get up. You need to check the the sleep/ wake up timer to see if it is set.
Jan 25, 2009 | RCA 32V420T 32" TV
RCA HDTV model#HD52W59. When I turn the power on it stays on for a few seconds and then goes off by itself.
TV turns off unexpectedly
• Sleep timer may have been activated.
• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this
happens frequently, the voltage in your house may be abnormally high or low.
• Unplug the TV. Wait ten minutes. Then, plug the TV in again.
Jan 05, 2009 | Televison & Video
Rca turfat
Check in the main menu for a sleep timer, sometimes they accidentaly get turned on.
Sep 24, 2008 | RCA 27F530T 27" TV
My RCA Dimensia TV from 1987 started to do this strange thing where the screen will turn off and on by itself while a loud clicking noise would come from the back of the set. This sort of thing has...
from original owners manual
check sleep timer or alarm time functions
electronic protection circuit may have been activated because of a power surge
Aug 21, 2008 | Televison & Video
27" FLAT SCREEN RCA, KEEPS TURNING ON AND OFF BY ITSELF
power board has suffered a spike it is damaged I suggest a new main board to replace the damaged one. you may find one on ebay.
Jul 22, 2008 | RCA LCDX2722W 27 in. Television
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
