First check to see if the pc is set to boot from the cd first. If that doesn't work, try and see if you can go to the command line. If you can, change the directory to your cd drive. For example: D:, then type cd d:, when you see the D:, then type setup.exe
Do you have the raid drivers installed ?
check with your mb instructions on correct install procedures.
check mb offical site for update of mb drivers .
is another op system on the drive you are trying to reformat?
is the drive setting on slave , master .or cable select?
check these see if it any help ..
