Question about RCA RTD170 System
I put it into progressive scan mode by accident
I tried all the resets i could find and none worked, are there any dip switches or anything inside the unit i can do to reset it to factory defaults?
Thanks
Jeff Roselli
jeffroselli@GMAIL.COM
  • Anonymous Aug 09, 2008
    cannot get the panasonic tv to recognize the signal
  • Patrick Sourander
    Patrick Sourander Sep 08, 2008
    I also put my player in progressive scan mode and cannot get it out. I can't even see the screen to use the menu options. If you have a solution please email me at psourander@gmail.com
I am having the same problem!
Posted on Mar 19, 2008
My sony dvd slv-300p blue light progressive scan light is on and i cant do anything ?
my sony dvd vcr combo has a progressive scan flashing light when plugged in. i put a vcr in and now it's stuck. none of the buttons seem to be working. it is making a clicking sound inside on machine. how can i get this thing to work again?
Jan 23, 2011 | Sony SLV-D300P DVD Player/VCR
I accidently hit the progressive scan button and now I can't get a picture when I try to watch a dvd.
just talked to LG Customer support and got them to send me a manual.
to turn off the progressive scan insert a disk and once it starts playing press stop, then press stop again and hold for 5 seconds this will turn off the progressive scan mode.
Dec 09, 2008 | Zenith DVT412 System
Dvd and progressive scan
THIS IS COVERED IN THE MANUAL. I DID THE SAME THING A YEAR AGO AND RESET IT BY FOLLOWING THE INSTRUCTIONS IN THE MANUAL. DON'T HAVE IT HANDY AT THE MOMENT BUT YOU CAN FINDI IT ONLINE. KEEP IN MIND THAT THE PROGRESSIVE MODE ONLY WORKS WHEN YOU HAVE IT CONNECTED VIA PROGRESSIVE SCAN.
Jun 10, 2008 | Toshiba SD-V55HT System
Magnavox MDV560VR DVD Player Stuck in Progressive Scan
Trun the DVD player on till you see the "progressive scan" screan. Hold the "stop" botton down for 5 seconds and the unit should reset to standard DVD play.
Worked for me, good luck.
Bill
Mar 13, 2008 | Philips Magnavox DVD/VCR Dual Player
My sanyo dwm-3900 is on progressive scan mode how do i fix this
If your DVD players is set to Progressive Scan Mode, tehn ther would be a light indicating it is so. The light is labeled P?scan on the bottom right side of your display window.
You can disable/turn OFF the P/Scan mode in the "Setup menu".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
DVD/VCR stuck in Progressive scan mode
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS. Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk. Try it & Good Luck!!!!!!!!
Nov 02, 2006 | Zenith XBV442 DVD Player/VCR
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Picture problems
Scrolling/black-and-white/"out of tracking" display on a DVD player is generally caused by the DVD player being switched into Progressive Scan mode on a TV not capable of viewing that content. Scan the remote for a button labeled Progressive, I/P, P.Scan, or anything similar. Scan the user manual for information on resetting this also. If the manual and remote come up dry, call Protron and see if there's a key combo you can hold to reset that. Often, holding Play for 5-10 seconds will reset to standard (Interlaced) mode, or holding Stop while turning the unit on. Sometimes, holding Display on the remote for a few seconds will also switch this setting. Good luck.
Jul 11, 2006 | Protron PD-800 DVD Player
RCA RTD170 System Logo
103 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
