Question about BenQ FP71G 17" LCD Monitor
Monitor always come on and off
Many times when i use the monitor, it displays well at the POST screen but it seldom loose signals when it is in windows
    Champion:
  • 220 Answers
What do you mean by loses signal does display go off with power led on? If so resolder 2Sc 5707 transistors on invertor board .They could also be short or leaky.
Posted on Feb 25, 2008
Cannot Display From Monitor
How long have you waited for it to boot? I know some servers take forever before they send a signal to the monitor. However, if you're get the monitor test screen or "no signal" screen, this usually is a sign that the monitor is not getting any signal from the server, indicating a bad cable or loose connection or the like (though not always if it's still booting). Have you looked in the server cabinet to make sure nothing is broke on the on-board connection or something? Is the DVI port you mentioned on the external PCI card? What does it plug into? I'm guessing you've checked for any installed video cards. Is there another port on the front or anything under a panel?
Nov 27, 2013 | Sun Fire V40z Server
Monitor has white screen
Hi
After understanding your issue with the monitor I hate to say this but unfortunately you have to consider replacing your monitor.
Thanks for using Fixya
Feb 21, 2013 | HP w1907 LCD Monitor
White horizental lines across the LCD Monitor.
This is a high voltage horizontal output problem. Could just be a loose connection or an intermitant component failure. If you can get into it, check for any loose connections. Sometimes this can also be caused by a large accumulation of dust. Make sure you unplug it before opening it up.
Apr 04, 2012 | HP LP2465 24" LCD Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Power indicater light is orange instead of green and computer screen is black
This usually indicates no signal from the video card. If this happens at boot and no POST screen display is seen, try checking the connections between the monitor and the video card, there may be a loose cable. Inspect the ends of the cable for bent or damaged pins. Or try swapping the connection cable.
If this is happening after the post screen, then you have a video driver problem, which can be resolved by booting into safe mode, uninstalling your video card drivers and restarting into normal mode.
Hope this helps,
Gill
Jan 29, 2010 | Direct Source Distributing IBM G70 (Black)...
My screen doesnt get a signal from the computer what could be wrong?
There could be three reasons for the same .
1. Loose signal cable: Check and reseat the VGA or DVI cable from the back of the system tower to the monitor.
2. Bad monitor : Disconnect the monitor cable from the back of the monitor check if the monitor displays anthing .
3. Bad video card : Try connecting an alternate monitor to check if the same is displaying anything on the screen.
Proton
Jan 07, 2010 | Acer Aspire T310 PC Desktop
Sony Screen Colors
it may not have problem of monitor first take the post (power on self test) to do so you have to disconnect 15 pin signal cable from cpu and power on it will give display without cpu the massage "no signal check signal cable" will appear then monitor is ok problem is in cpu. if no display come then problem in monitor
Oct 25, 2008 | Computers & Internet
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Acer AL1716 (black) - Drops to No Signal -
Eric,
My apologies for the rude treatment you received from one of our Experts. I have deleted his post. I will be dealing with the Expert personally, and will also request that one or more of our Experts who are familiar with Acer Monitors come assist you with this question.
Again, on the behalf of FixYa, I offer my most sincere apologies.
John Goodman
Community Manager
experts@fixya.com
Feb 14, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
85 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
