Ruud UBHC Air Conditioner
Problem for Ruud UBHC Air Conditioner
The exhaust blower starts for about 15 seconds
By mickeyandbra on Oct 20, 2009
the exhaust blower starts for about 15 seconds then shuts off. several minutes later, the same thing happens - over and over
Solution #1
posted on Nov 06, 2009
Not Rated)
checkops
Rank: Apprentice
Rating: 0%, 0 votes
goodman furnance the exhaust fan starts, igniter glows hot, all burners lite up & will burn for about a minute and shuts down . I think it senses the room blower does not start so it shuts down.
Was this helpful?
Yes
No
Solution #2
posted on Oct 20, 2009
Not Rated)
Therinnaiguy
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 398 votes
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
I suspect you have a bad igniter, you did not mention if it glows or not or a blocked air intake or exhaust pipe. Also check the condensate hoses for a blockage. While you are looking, change the air filter.
Was this helpful?
Yes
No
Popular Solutions for Ruud UBHC Air Conditioner
Questions and Unsolved Problems for Ruud UBHC Air Conditioner
Do you recommend Ruud UBHC Air Conditioner?
Answer
Answer
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging... (More)
Answer
I have a similar problem. It gets up to 78 degrees in the house and the ac unit is set to 65. It... (More)
Answer
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut... (More)
Answer
I have messg error 6 waht mining my air condtion Ruud
Answer
I have a ruud ac unit running heat for the second time this winter and now not heating. blowing cool... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ruud UBHC Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
