Question about Innovage 69420210126 Phone
Other phones do not work
When i have the innovage phone plugged in other phones will not work, the just keep dialing when i try to receive or place a call.
please help!!!!!
11
Turn Off Spy Protection. Press (#) for 2 Seconds
Posted on Jan 23, 2008
Keep getting dial tone on my phone, unable to receive or send calls
Step 1:
try turning off the phone taking the battery out for 15 seconds then re inserting it and turn the phone back on
Step 2:
if that does not work then try to factory reset it
Step 3:
then if that does not work take it to the store and ask them to troubleshoot it
Dec 11, 2012 | HTC Cell Phones
I have a Shift 3 lcd touch panel phone with 12 digit calculator.I cannot find the manual for this phone.I can receive calls but cannot call out.A manual would be helpful Thanks
  • Check your phone to make sure it is set up properly. Open the back of the phone by pressing your fingertip on the small lever that opens the battery area. The battery cover will come off in your hand. Insert three "AAA" batteries into the back of the phone so you can use the night light feature. Replace the battery cover by sliding it into the battery area and clicking it into place with your fingers. Connect the phone to the telephone phone jack by connecting one end of the wire to the phone and another end to the wall jack. Connect the handset to the phone by inserting the end of one end of the curly phone wire to the handset and the other end into the side of the phone. Listen to the dial tone by pressing the speakerphone or picking up the handset to make sure your Innovage LCD touch panel phone is connected.
  • 2
    Review calls you missed. Use the up and down arrows on the Innovage LCD touch panel phone to view the caller ID phone numbers.
  • 3
    Use the night light to view the Innovage LCD touch panel in the dark. Slide the switch on the front of the panel to turn the night light function on. Slide the switch to the off position to turn the night life off.
  • 4
    Adjust the volume on your speaker by selecting the speaker loudness that you want. Press the hands free button once and press the "Delete" button. Choose a loudness from one to four.
  • 5
    Press the hold button on the front of your Innovage LCD touch panel phone. This will activate the hold function when you are on a call and it will allow music to play while someone is on hold. The hold music is built in to the phone and will automatically play when you press hold.
  • 6
    Save a phone number as a VIP number on your Innovage LCD touch panel phone. Press set and save when an important number comes onto your caller identification. This makes it harder to delete the phone number by accident.
  • Read more: Innovage LCD Touch Panel Phone Instructions ' eHow.com http://www.ehow.com/how_7256783_innovage-touch-panel-phone-instructions.html#ixzz1eMIaaXLV
    Sep 23, 2011 | Innovage Speaker/Caller ID* LCD Touch...
    I am setting up my Innovage Deluxe Corded Handheld Mini Flip Phone for use with my MagicJack while traveling. 1. I can receive incoming calls fine, just pressing the green phone button to connect and...
    First i would say both units are still in good condition as you can still receive calls from them comfortably without any hassles. If you cannot dial out it is probably as a result of the area code or the dial code not being set correctly. The area code helps to determine which location the home phone is situated to enable the calls to be routed through the proper channels to enable connectivity. The dial out code basically does the same as the area code. Both of them are just like address systems to determine where and how the calls are routed. Try setting both codes and see if the calls still dont go.
    Hope this solution has been helpful?
    May 01, 2011 | Innovage 1502084 Corded Phone
    I get no dial tone unless I wiggle the handset cord at the handset. The speakerphone works as long as I do not move the handset cord.
    Try replacing the telephone cord between your handset and phone base cradle or swap the plugs around between your handset and base.
    Dec 24, 2009 | Innovage LCD Touch Panel Phone
    How do i turn the ringer off? Innovage LCD flat
    there is a tiny button at the base of the phone, just to the right of where the phone jack is plugged into the phone. Three settings - Hi, Lo and Off
    Oct 28, 2008 | Innovage Speaker/Caller ID* LCD Touch...
    Weird..Cound't dial out
    THERE IS A BLOCKING FEATURE IN THE MANUAL ON PHONES ON THE SAME LINE ,FIND IT READ IT MAYBE THIS WILL HELP
    Oct 07, 2008 | Innovage 69420210126 Phone
    Changing settings on innovage telephone
    hi big al,
    on my phone you hit SET/SAVE, press UP/DOWN to find the function you want, press SET/SAVE again to select, press UP/DOWN key to program. press SET/SAVE to confirm. i can email you a copy of my manual if you'd like. my email is all8upinwv@yahoo.com hope this helps.
    tammy
    Apr 19, 2008 | Innovage Speaker/Caller ID* LCD Touch...
    INNOVAGE TALKING CALLER ID LCD TOUCH PANEL PHONE
    there is a "special feature" for privacy that can be turned on or off...when on it is supposed to keep others from eavesdropping - but it actually will not let other phones work...turn that off (settings 1 is for date, go to settings8) and it will complement your other phones and work.!!
    May 31, 2007 | Innovage 1502084 Corded Phone
    Innovage 69420210126 Phone Logo
    Top Innovage Lands Phones Experts
    wiccan8thhouse
    wiccan8thhouse
    Mohamed Ismail
    Mohamed Ismail
    Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
