Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
The cover for the lens has fallen off
The camera was dropped. The cover for the lens has come off and the two black parts that close to gether to cover the lens have also fallen off. Nothing appears to be broken. Please advise me on how to re attach. Should I fix it when the camera is switched on and the lens is in the open position?
You can e-mail me on desmond_strachan@hotmail.com
Thanks Des
    Master:
  • 619 Answers
You can view and touch broken portion in on position remove battery still lense is out , remember this is very sensitive parts might it will broken let camera technician do it for you.
Posted on Dec 29, 2007
Fix camera lens fell out
replace the lens or just but a band aid over it if your never going to use it.
Mar 14, 2014 | Acer Aspire Computers & Internet
Broken lens contact...Can't find replacement part
You may order the lens mount assembly or just the lens mount from here.
Nov 26, 2012 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
I dropped the camera and now the lens cover does not stay open or closed. It no longer clickes when it is open or closed.
clicking is done when the lens unit/camera i ok,when the camera dropped lens unit must be damaged,so it should be serviced/replace with a new unit
Mar 04, 2010 | Cameras
Sony Cybershot DSC-P52: Lens Cover Failure
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it's something simple, a power-down reset may help. Turn the camera off, remove the battery, let the camera set for at least 30 minutes, then replace the battery and power up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 18, 2009 | Cameras
Lens shuts close
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 04, 2009 | Cameras
Lens cover doesn't open when switching on
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either one of those problems will require professional repair. If it hasn't suffered from a drop, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be to weak/worn to properly power the camera, or the camera may require professional repair.
Oct 16, 2009 | Olympus MJU 400 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Blurry display after dropping
I did the same thing to my Photosmart E327 and upon inspection, I found that the len had fallen out. I could not find it so I am trying to find how to get it replaced. The blurry picture began for me after the drop. Suggest that you check to see if your len has become dislodged, or fallen out as mine did.
Dec 03, 2007 | HP Photosmart E327 Digital Camera
Camera lens cover is sticky
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jul 27, 2007 | Casio Exilim EX-Z55 Digital Camera
Lens cover sticks closed.
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
Sep 30, 2006 | Fuji FinePix A303 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
172 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
